Robert 314
- Oct 15, 2015
- 63
- 35
- MH within 3 months.
- Converted van. 5 yrs exploring.
assuming (possibly in error but feel free to research and prove me wrong ) water heating panels to be similarly rated on a Watt/surface area basis you're going to struggle to generate any meaningful heat unless you're on the equator in mid July in which case you probably won't need heating at all.
in warmer climes a lot of people use a black water container left out in the sun to supplement there hot water demands
You see them a lot at festivals where they're called "solar showers"
Never used one so no idea if they're any good.
thats not quite true in hot sunny weather a good solar will get extremely hot which is why its usually mixed with cold for useIt's a different type of system. Solar hot water is an indirect cylinder system with a cylinder full of an anti-freeze type solution which is pumped round the panels and the hot water heated via coils in the cylinder. It doesn't heat it to usable temperatures, just increases the ambient temperature so the primary heat source (boiler or whatever) doesn't have to do as much.
Even if such a system was viable for a motorhome the weight of it would be a killer.
I understand all that, I was simply commenting on an energy level harvest point of view. Ignoring the weight issues you probably couldn't fit enough panel surface area to a motorhome to harvest sufficient energy to boil a kettle once a day never mind provide heat in meaningful levels.It's a different type of system. Solar hot water is an indirect cylinder system with a cylinder full of an anti-freeze type solution which is pumped round the panels and the hot water heated via coils in the cylinder. It doesn't heat it to usable temperatures, just increases the ambient temperature so the primary heat source (boiler or whatever) doesn't have to do as much.
early direct systems suffered badly by overheating which is why they are now pumped so that flow can be stopped when its getting too much heat
only the coils a small header and panels contain glycol the cylinder is still filled with water
the biggest draw back for a motor home is they all work on bulk storage which would be impractical in a motor home
D.
Yes, they are....but you dont need to add any cold water to your shower.You see them a lot at festivals where they're called "solar showers"
Why would you drink from the hot tap.....hot and cold are isolated.This made two things happen. The first one was that the tap water tasted of anti freeze.
