Solar Garden lights ? (1 Viewer)
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
Gaffer wants a couple of those solar garden lights. There are no lights here at all ! No street lights and no neighbours close by which we both really love but hell is it dark at night !
There are loads on Ebay and Amazon but I don't want to by cheap junk so wondered if anyone has any they can recommend ? Only want a couple on the fence posts and one or two in the lawns so don't mind spending proper money for proper kit . I cant make head nor tail of the power battery numbers on the few who even supply them,
Cheers !
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
Buy some 12v led trailer marker lights in white,
Wire them up to a 12v plug, transformer which many homes have from redundant computer etc equipment.
Switch on when required.
I have them wired up along my fence in the rear garden, brill, in both ways.
Charlie
Charlie
3,211
3,639
Im a newbie
Thanks.. Prefer just to pop a couple on the fence and a couple in the lawn and be done with it...
Chris
21,006
274,532
None
10 years
In my experience , solar lights are rubbish.
They give off no real light and soon pack up altogether.
The only one I have which is good is a motion detector spot light at the end of my garden which is quite bright, but that's only because it doesn't come on very often.
Carol
14,042
111,433
North Wales.
Think I have to agree the only way is to renew them as they fail which they usually do in the end and strangely it does not seem to make any difference how much you pay not much in it.
Cal54
3,778
61,426
Southport, UK
Leisuredrive Renoir
Since 1996
My advice would be to go with cheap ones and just change as necessary. You can pick up any shape etc and colour changing ones which are very relaxing. £2.99 each will normally last a couple of years from our experience.
FJmike
972
1,046
Swindon
over ten years
Same as Carol buy cheap and replace once a year. I bought some expensive solar lights and they didn't last as long as the cheap ones.
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I 've bought cheap ones in the past, lasted a year. My neighbour bought more expensive ones from a garden centre and they're still bright after 2 years at least.
I replaced my cheapie a with dearer ones from local garden centre so I'll have to see how long they last --- looking pretty at the moment as they're the colour changing ones.
I can't see what would make them vary as all made in China :(
Shrimp
May 27, 2015
3,962
32,897
Bedfordshire, UK
Hymer B584
Long time
Mostly the cheap solar lights are ok-use them until they don't work & replace-usually effective for about 12 months.
I did find some, string of lights, with a separate panel, they are still going at 2 yrs old, got from a garden centre but can't remember what the makers name was & as we are in France & the lights are in UK......! The other way to go, string of lights again, you can get some that are battery-not solar-operated, they come on for 6 hrs off for 18(I think) on again for 6 hrs & so on.
Jan 28, 2008
10,104
18,259
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
most of those ive seen have a 40mm sq panel which just about powers a single led via a couple of aaa batteries ok for decoration but useless as a source of light
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
Would it work with string lights up the guy ropes connected to a small car battery with a small solar panel, ie 20 watts.
Charlie
Charlie
3,211
3,639
Im a newbie
Following the advice I picked up some cheap ones in Home Bargains. I go in there to pick up the huge amounts of bird food we put out in our gardens as we both love to see the birds coming into the garden. They were less than 3 quid each and the boss loves them ! Just a subtle light and though these things are not my bag they do give a nice effect...
Thanks all !
Anthea M
Oct 18, 2015
9,501
165,134
Sheffield
Hobby
Since 2009
Charlie sounds like you have both settled in to your new home well! That's great after all the trauma . Enjoy!
Charlie
Charlie
3,211
3,639
Im a newbie
Thank you ! I cannot find the words to tell you how happy we are ! We are right out in the sticks and it's so quiet ! Ok there is much work to do but that's what I do anyway buildings. I can't imagine what it would all cost if we had to employ someone to do it all but all we have is the materials and the specialist services like gas ( LPG) and plumbing and electrical which I won't touch. We both feel instantly at home. Again it's not possible to put into words how one can feel comfortable . At ease. And we'll just plain right if you know what I mean. (y)(y)
Aug 10, 2012
834
881
cambridge
Globecar
since2001
Hi Charlie
Not solar but it is led:) related
For years my back yard has been lit with a ' sonopac' sodium 70w flood on a dusk to dawn switch
Just replaced it with a warm white led flood light , 20w, from screwfix, fantastic
Wouldn't go back to the yellow sodium and it runs at a 1/3 of price.
Enough light to walk around, but not too bright(y)
Dec 12, 2010
5,367
21,177
Cumbria
since 2011
We've had a string of solar fairy lights around the pizza oven for a few years now. They packed in after about 18 months so I took the panel apart and replaced the battery. It's AA size but 3.2 volts not the usual 1.2 volts, cost 3 or 4 quid off ebay and has lasted almost 4 years and is due replacement again now as only the green leds light up (lowest voltage drain I think)
Aug 6, 2013
11,941
16,527
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Hi Charlie
I don't know whether it's of any interest (to you or anyone else with sodium lighting) but the sodium tube can be replaced with a metal halide tube of the same wattage, uses the same control gear, but gives off a white light.
Aug 10, 2012
834
881
cambridge
Globecar
since2001
hi tony, thanks for the info:)
when ever I looked at metal halide they were always a lot more money
I have replaced the sodium floodlight with this <Broken link removed>
I had no great expectations, but WOW, it is better than the sonpac and at 20w vs 70w!
Gently lights a 100' garden with warm white and then some, for the application , very pleased
