Solar controller load (1 Viewer)
Dec 5, 2013
317
249
Somerset
Newbie
What do you use your solar controller load connection for?I know it can be use for low amp equiptment, but I just wondered what other Funsters use them for.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Mine can handle 15 amps and I used to run a large cool box with it.
Now I feed the wifi hub and feed the aerial USB lead through the door seal
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
12v cig Socket same as previous post inside the van charging a 12v hand lamp
If anyone carries a jump starter pack these need almost constant charging to work properly and maintain fitness for purpose, the Solar load out put is a good way of maintaining these:thumb:if you have no better use for it:thumb:
G
mikekaren2
Dec 5, 2013
317
249
Somerset
Newbie
Looks like a12v accessory socket may be on the cards.Anyone used it to power the porch/door light?
UK Pete
284
333
kent
Renault van conversion
on/off since 1991in campervanss
I have yet to find a use for mine, can someone tell meif it is only supplying power while the panel is operational in sun light?
pete
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes it is on all the time. Some controllers have an on/off timer facility also.
Most if not all will have a low voltage cut off point.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I run a 150w inverter of mine and use it for all charging of accessories, TV sat etc. if battery voltage drops too low it cuts off. only ever done that once after having the TV on for 10 hours on wet day.
mikekaren2
Dec 5, 2013
317
249
Somerset
Newbie
Would a 12v hair dryer work on the load feed, how do I work out theWattage & do any of the ladies have recommendation for a 12v hair dryer?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not a lady but most ladies throw them in the bin :roflmto:
The load feed as you refer to it is not different to connecting to the battery.
camcondor
1,034
480
East Midlands
Agree with Techno.......12V hairdryers are possibly the most ridiculous gadgets ever made! Good for the bin! They really are not fit for purpose, I think they would even struggle to dry a Barbie dolls hair! :ROFLMAO:
mikekaren2
Dec 5, 2013
317
249
Somerset
Newbie
No hair dryer then, back to towel dry & the birds nest look for her!
43,301
49,286
i would like to know where all these high aux output controllers come from ?
Both my last and current ones, both MPPT, have a max output of 2amps on the aux load connections
Techno
Jul 28, 2010
15,475
20,756
May 2010
Mine will carry 40 amps as long as the wiring is suitably sized.
Broken Link Removed
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
I run my 300W inverter off it. This is used for the laptop chargers (too many of them to all have 12V PSUs). I can set the minimum voltage much higher than the default to ensure the battery never gets anywhere near low on such frivolous usages.
