Solar Controller 'Lamp' Terminals (1 Viewer)
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
On my Phocos CA controller, which is fitted in the garage, there is a pair of termination points with a Lamp marked, obviously to connect a 12v lamp.
I know folks have used these to power a wifi router, but does anyone know the power limit for these connections, I want to run a 12v Cigar socket into the garage and want to fuse it safely.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
the power is limited to that of the controller, i.e, 10W or 20W or whatever you have fitted.
Be aware those controllers were made to control street lighting so you have to program that connection to always on, always off or a set number of hours after the solar stops generating power i.e at night. Anything connected to that port will shut down if the battery falls too low, thus protecting the battery.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Some like mine are just ON no time setting. Roger means amps (y)
Sheddy
Oct 20, 2010
2,248
37,617
Since 2003
Mine is ON full time, checked it in the dark, I will fit a socket and fuse it to 3 amps, which should be OK.
