solar connectors
Discussion in 'Tech/Mech General' started by mitzimad, Oct 4, 2016.
  1. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,346
    3,783
    walthamstow east london
    looking to put panels on new van but unsure the best way to join them last time i did some i cut the connectors of as they cant go through the glands and i jointed them inside a 1p rated box which i glued to the roof and drilled down through box and roof
    am i missing a better solution using the connectors?
  2. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,394
    13,331
    cowdenbeth fife
    To be honest the smaller the hole the better what I did was stekaflext the box on after I had fitted every thing Putin plenty rund the hole before pressing the box in to place this seal the cabil and box in one go done this three years ago no problems so far
    Bil
  3. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,881
    6,016
    Guisborough
    I am sure your panels will come with leads and Mp4 connectors, you can get 2 into 1 connectors if you want to join a couple of panels on the roof and then just go through 2 glands into a box on the roof
    I didn't want these big ugly branch connectors so I made up a box and put 6 glands from the 3 panels and then joined everything inside.
    Martin
    • Informative Informative x 1
  4. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,388
    3,157
    Kendal, Cumbria
    Cut connectors off then fit new ones once past glands.
    • Like it Like it x 1
  5. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,825
    3,485
    Cumbria
    I cut mine off too and ran the wires down behind the passenger side door pillar and mounted my LR1218 behind the little tin plate that sits behind the seat mount and the floor, can't really see the solar unit but it's in there behind the little fuse box. Makes for a short run to the eBox unit.
  6. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,346
    3,783
    seems i did it much the same as everyone else i looked at he branch connectors but can t see the sense of having all that on the roof and how to hold it still
