Solar connection to EBL 101 (1 Viewer)
Jan 31, 2016
1,900
3,374
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
I read some advice on here about putting solar panel on my Hymer 552CL. One of the recommendations was to use an MPPT Solar Charge Controller which I bought.
I'm going to fit my 120w panel through this Solar MPPT then into the EBL101 input.
Now I've read that this may cause problems with the EBL101 and now don't know what to do.
Any recommendations ?
lunarman
2,155
2,451
South Glos
since 1994
you should use the Schault lr1218 solar controller with the ebl101. I originally had a panels connected direct to the batteries via a controller which confused the electroblok and it was not until I connected using an lr1218 via the ebl unit that the system recognised the correct charging regime.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Or, if you want an MPPT model, the Schaudt LRM1218.
For a definitive answer, email Udo Lang at Schaudt (but another post suggested he may be on holiday at the moment). Udo.Lang@schaudt-gmbh.de
JeanLuc
3,304
2,199
Warwickshire
Maybe - maybe not. Ask Udo whether you can connect the specific model controller that you have bought into an EBL101.
BusyBuilder
Jan 31, 2016
1,900
3,374
Hymer B544 (2012)
newbie
okay slight balls up I have the EBL99 not the 101.
I need to get this done this week ideally so if I have to use the Schaudt LRM1218 I can get one from Brownhills and sell my Solar Controller. I've mailed Udo in the meantime, I've spoken to Brownhills, but Darren isn't in today.
Thanks for advice.
JeanLuc
3,304
2,199
Warwickshire
The EBL99 is relatively 'un-fussy' regarding solar controllers that can be connected to it according to correspondence that I have had, and others have reported, with Udo Lang. It is possible to connect a non-Schaudt regulator to Block 6 on the front panel. You will need to use a three port male MNL connector block and get the correct pins to go in the block. These are crimp-type and it is important to get them in the correct holes first time as they are held in by barbs and are very difficult to get out once pushed in place. (The male block can, of course, be plugged in and taken out of the EBL with ease - it's just fitting the pins in the connector that is a 'one-time' task.) The MNL connector pin locations are marked with very small numbers; the EBL99 requires that you use Pin 1 for the negative cable and Pin 3 for the Positive cable from the regulator. The correct MNL block and pins can be purchased from Schaudt, or you can probably source them locally / via Ebay etc.
Note that the maximum current loading for the EBL99 via Block 6 is 15 amps (although the Schaudt regulators are rated at 18 amps max). So long as your present regulator complies with this, you should be able to use it.
Alternatively, the benefit of the Schaudt regulators is that they are twin-battery models: i.e. they will charge both habitation and starter batteries. If your present one cannot do this, you may want to consider a swap. The Schaudt regulator models are LR1218 (PWM-type) and LRM1218 (MPPT-type). I have the former and it works very well with a 135 watt panel connected to an EBL99. Also, the regulators are supplied with wiring looms to plug into the EBL.
The LR model is about £70 and the LRM is about £150.
BusyBuilder
Jan 31, 2016
1,900
3,374
Hymer B544 (2012)
newbie
Sorry to be a pest, I've looked all over for a supplier (incl ebay) of those connector blocks and MNL pins, I've looked at Schaudt but it comes up in German.
Any ideas ?
SandraL
1,373
985
Somerset
Hymer b694sl
Try mate n lok on ebay, be careful to check exactly identical !
Lenny HB
53,308
149,488
On the coast in West Sussex
Hymer B678 DL
So I've wasted £90 on a Solar Controller then ?
Nope, both the EBL 99 & 101 the solar connection is straight through just connects straight to the batteries via a fuse. If you have a dual output solar regulator you can connect directly to the EBL as Philip mentions or if it is a single output you can fit the CBE Solar split charge relay, that is what I did in my van (EBL29).
The EBL101 has straight through connection as mentioned above so doesn't matter what solar regulator you use.
SandraL
1,373
985
Somerset
Hymer b694sl
If the ebl has ability to show battery capacity itmay be a problem connecting straight to battery. To work out capacity ebl uses the shunt inside the ebl to measure both charge and discharge. If it cannot measure the charge it will display incorrect capacity, it cannot measure charge from solar if solar is connected direct to battery. Now taking cover........as there are probably many who can explain where i have gone wrong.
Lenny HB
53,308
149,488
Hymer B678 DL
QUOTE="SandraL, post: 1970690, member: 19577"][/QUOTE]
Depends what control panel is fitted, doesn't make a lot of odds as you can still see battery voltage just won't see the solar current flow, a decent Solar regulator will have all that info anyway..
JeanLuc
3,304
2,199
Warwickshire
Any ideas ?
Email Udo and explain what you are planning to do. Ask him to supply the relevant MNL male block and pins for your EBL (I think the pins come in batches of ten). They are not that expensive - I think I paid about €10 but most of that was postage. At least you will have the security of knowing that they have sent the correct type.
If Udo is not available (holidays?) you could also try this lady - Janet.Pomino@schaudt-gmbh.de
BusyBuilder
Jan 31, 2016
1,900
3,374
Hymer B544 (2012)
newbie
I bought this one
on recommendations in another thread. And it's quite a weighty item seems very well made, as it's German designed I expect it to be the bees knees. it has all the information displayed you could need.
Lenny HB
53,308
149,488
Hymer B678 DL
They are AMP Mate-N-Lock connectors CPC stock them, these are the pins and Connector housing.
They have used a generic drawing in the connector listing if you look at the PDF and the AMP part number you will see it is the right one.
  • 1656593.pdf
BusyBuilder
Jan 31, 2016
1,900
3,374
Hymer B544 (2012)
newbie
Reply from Udo
Hi Andrew,
you can install any solar-charger to the system.
In this matter, the best would be to add the solar-charger to the leisure battery poles directly.
Best Regards
Udo.
and again
Hi again,
please recognize, the solar-input is good for maximum 15A!!
Better to connect the charger to the battery.
Best Regards
Udo.
so there we have it, I'll be doing all this tomorrow now my new Banner batteries have arrived.
Lenny HB
53,308
149,488
Hymer B678 DL
Banner don't ? or Alpha ? and are you saying Banner batteries are rubbish ?
Bann are rubbish and Banner don't honor their warrantie, they sell a battery as suitable for leisure use then will only accept a CAA test as proof it has failed. Mine passed the CAA test (starter battery test) but would only deliver 10A/H at low discharge used for leisure.
Just search the German forums to see how bad Banner are.
