Solar connection to EBL 101
Discussion in 'Solar Power' started by BusyBuilder, Aug 5, 2016.
  1. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
    I read some advice on here about putting solar panel on my Hymer 552CL. One of the recommendations was to use an MPPT Solar Charge Controller which I bought.
    I'm going to fit my 120w panel through this Solar MPPT then into the EBL101 input.
    Now I've read that this may cause problems with the EBL101 and now don't know what to do.
    Any recommendations ?
  2. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,484
    888
    South Glos
    you should use the Schault lr1218 solar controller with the ebl101. I originally had a panels connected direct to the batteries via a controller which confused the electroblok and it was not until I connected using an lr1218 via the ebl unit that the system recognised the correct charging regime.
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,925
    1,944
    Warwickshire
    Or, if you want an MPPT model, the Schaudt LRM1218.
    For a definitive answer, email Udo Lang at Schaudt (but another post suggested he may be on holiday at the moment). Udo.Lang@schaudt-gmbh.de
  4. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
    So I've wasted £90 on a Solar Controller then ?
  5. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,925
    1,944
    Warwickshire
    Maybe - maybe not. Ask Udo whether you can connect the specific model controller that you have bought into an EBL101.
  6. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
    okay slight balls up I have the EBL99 not the 101.
    I need to get this done this week ideally so if I have to use the Schaudt LRM1218 I can get one from Brownhills and sell my Solar Controller. I've mailed Udo in the meantime, I've spoken to Brownhills, but Darren isn't in today.
    Thanks for advice.
  7. wizza
    wizza Funster
    Aug 3, 2008
    116
    55
    Essex
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,925
    1,944
    Warwickshire
    The EBL99 is relatively 'un-fussy' regarding solar controllers that can be connected to it according to correspondence that I have had, and others have reported, with Udo Lang. It is possible to connect a non-Schaudt regulator to Block 6 on the front panel. You will need to use a three port male MNL connector block and get the correct pins to go in the block. These are crimp-type and it is important to get them in the correct holes first time as they are held in by barbs and are very difficult to get out once pushed in place. (The male block can, of course, be plugged in and taken out of the EBL with ease - it's just fitting the pins in the connector that is a 'one-time' task.) The MNL connector pin locations are marked with very small numbers; the EBL99 requires that you use Pin 1 for the negative cable and Pin 3 for the Positive cable from the regulator. The correct MNL block and pins can be purchased from Schaudt, or you can probably source them locally / via Ebay etc.
    Note that the maximum current loading for the EBL99 via Block 6 is 15 amps (although the Schaudt regulators are rated at 18 amps max). So long as your present regulator complies with this, you should be able to use it.
    Alternatively, the benefit of the Schaudt regulators is that they are twin-battery models: i.e. they will charge both habitation and starter batteries. If your present one cannot do this, you may want to consider a swap. The Schaudt regulator models are LR1218 (PWM-type) and LRM1218 (MPPT-type). I have the former and it works very well with a 135 watt panel connected to an EBL99. Also, the regulators are supplied with wiring looms to plug into the EBL.
    The LR model is about £70 and the LRM is about £150.
  9. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
    Thanks Philip, we'll try that first.
  10. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
    Sorry to be a pest, I've looked all over for a supplier (incl ebay) of those connector blocks and MNL pins, I've looked at Schaudt but it comes up in German.
    Any ideas ?
  11. SandraL
    SandraL Funster
    Jan 24, 2012
    300
    154
    Somerset
    Try mate n lok on ebay, be careful to check exactly identical !
  12. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
  13. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,500
    6,482
    West Sussex
    Nope, both the EBL 99 & 101 the solar connection is straight through just connects straight to the batteries via a fuse. If you have a dual output solar regulator you can connect directly to the EBL as Philip mentions or if it is a single output you can fit the CBE Solar split charge relay, that is what I did in my van (EBL29).
    The EBL101 has straight through connection as mentioned above so doesn't matter what solar regulator you use.
  14. SandraL
    SandraL Funster
    Jan 24, 2012
    300
    154
    Somerset
  15. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,500
    6,482
    West Sussex
    QUOTE="SandraL, post: 1970690, member: 19577"][/QUOTE]
    Depends what control panel is fitted, doesn't make a lot of odds as you can still see battery voltage just won't see the solar current flow, a decent Solar regulator will have all that info anyway..
  16. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,925
    1,944
    Warwickshire
    Email Udo and explain what you are planning to do. Ask him to supply the relevant MNL male block and pins for your EBL (I think the pins come in batches of ten). They are not that expensive - I think I paid about €10 but most of that was postage. At least you will have the security of knowing that they have sent the correct type.
    If Udo is not available (holidays?) you could also try this lady - Janet.Pomino@schaudt-gmbh.de
  17. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
  18. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,500
    6,482
    West Sussex
    They are AMP Mate-N-Lock connectors CPC stock them, these are the pins and Connector housing.
    They have used a generic drawing in the connector listing if you look at the PDF and the AMP part number you will see it is the right one.
  19. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    186
    98
    Cromarty
    Reply from Udo
    Hi Andrew,
    you can install any solar-charger to the system.
    In this matter, the best would be to add the solar-charger to the leisure battery poles directly.
    Best Regards
    Udo.
    and again
    Hi again,
    please recognize, the solar-input is good for maximum 15A!!
    Better to connect the charger to the battery.
    Best Regards
    Udo.
    so there we have it, I'll be doing all this tomorrow now my new Banner batteries have arrived.
  20. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,500
    6,482
    West Sussex
    Hope they last more than the 18 months the Banners that were in my van lasted.
