Solar Charging / How Long From Flat ? (1 Viewer)
RS_rob
1,010
669
Turnford
over a Year Yay................
This is a theoretical question prior to actually putting it in to practice.
My MH has a solar panel possibly 100 watt I don't know fer sure as there are no markings to determine the size.
My leisure battery is 85amp & I only have the one for now.
So assuming the above & taking into account I have flattened my battery overnight say using a plugged in fridge (& this is not a question of how long my cool box will last on battery)
How long would my battery take to charge on solar alone...................?
Minxy
32,649
66,534
E Yorks
Carthago Compactline
.... how long is a bit of string! Depends on how much light there is for a start ... and whether you've totally stuffed your batteries in the process of letting them go flat ... best to get a second battery fitted to take advantage of all the power the solar panel is producing on a good sunny day then you won't ever have to find out! :D
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
As a rough guess I'd allow a week of average summer weather and assuming no other draw on the battery during that time.
But, as stated already, lots of other factors and equipment efficiencies involved.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
A plugged in fridge?
It would be flat in no time!!! That is why m/home fridges only run on 12v when engine is running!
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
The question is further complicated by the fact that whatever drained the battery overnight might also be running during the day, diverting the solar power.
The panel also won't produce 100w, perhaps only 30 averaged over a 12 hour period, it depends on the season, weather and latitude.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
well at midday your solar may produce 5 amps the est of the day 2-3amps, assuming you only depleted the battery by 50% i.e. 42.5 amp/hrs then I'd guess on average 2 days to really recharge it, not just to show 13.8V which would only be the charge voltage anyway. If the fridge or cool box is still plugged in the you have probably killed the battery anyway. Should only be on 12v when the engine is running. If you must run a compressor fridge or cool box on 12v then it should be connected to the load terminals of the solar controller so that the controller protects the battery and switches off before any damage is done and then remains switched off until the batteries have recovered a bit.
9
9526
Wildman's figures are a good guide.
In my experience with a 100w panel a sunny day will give you 20-30 AH's worth of charge.
Scotland less so, the South of France more so :)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Sorry guy's, but UK sun you have NO chance of fully charging a battery.
Average UK day 100 watt panel 15/20 amps MAX, why watch your solar charger ( that is if you have one with an amp read out ) 1 second you have 3 amps next second you have .5 of an amp because of cloud or angle of sun to your panel on the roof. So if NOTHING is connected to battery at all other then solar panel it would at best take 5/6 days, however as it is connected to the MH and drawing amps however little that is it WILL never charge ONLY "Top up" the battery.
Average MH draws 3 amps an hour ( lights, pump, etc ) but most these days draw around 5 amps an hour (lights, pump, TV, DVD, phone the list goes on and on ) so: 5 hours at 3 amps is 15 or 5 hours at 5 is 25 amps.......... but your UK 100watt panel is only giving you 20amps.......... So to answer the OP'er NOT A CHANCE of CHARGING BATTERY alone. Sorry
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
solar has accounted for 100% of my motorhome charging for the past 5 years, whilst there is less sun than spain it does work in the UK. My 2nd battery bank is not connected to the alternator only the solar. Batteries are normally fully charged by lunchtime even when overcast. It is a matter of how much battery power and how much solar you have.
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
correct me if im wrong but I didn't think solar panels would charge a battery ,only trickle current to keep them topped up.if the battery has been totally flattened then there is no chance of the solar panel bringing it back to life.
Brian & Jo
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
4-5 amps is a decent charge rate, I suppose it all depends just how low a battery has been discharged, below 10.5v irreparable damage has been done anyway. Plus you cannot charge a "dead" battery any more than a conventional charger can.
Don Quixote
2,966
5,258
VW T6 Campervan
C
Brian & Jo
Correct.................
Don Quixote
2,966
5,258
VW T6 Campervan
4 or 5 amps at 14.4 volts is charging at 13.???? is topping up.
Nov 12, 2010
149
83
Northamptonshire
Hi Top
5 Years
from a different view, when not in our MH we live on a narrowboat, this boat is fitted with 4 * 110 AH leisure batteries, it also has a 100 Watt solar panel.
If we leave the boat moored up and go elsewhere, like a funster meet and the batteries are flat! when we come back 3 days later the batteries are fully charged and that is with a 12 volt fridge running all the time.
I can assure you the boat seldom goes anywhere other than UK ( sorry England) and thus that is the sunshine levels we are used to.:)
I base my evaluation of battery state on a fairly sophisticated battery management system and good number of years living at the mercy of battery state.
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
I don't know what I have done wrong but I made my solar panel lest year flattened my battery's completely dead after leaving the light on when it was in storage over winter
I replaced the controller after I got out of hospital six days later the battery's were fully charged and all green in the indicator window.
Wee have ben away for a full week using TV lights DVD's game stanchion's was off grid no power problems
bill
