Solar charge controller change
Discussion in 'Solar Power' started by Foghorn Leghorn, Jun 26, 2016.
  1. Foghorn Leghorn
    Foghorn Leghorn Funster
    Oct 26, 2014
    223
    153
    Dumfries and Galloway
    I want to change my charge controller for a one with a digital display , is it ok to disconnect the original one and reconnect the replacement while the roof mounted panel is exposed to the sunlight or do I need to cover it up ......thanks
  2. Boycie
    Boycie Funster
    Sep 25, 2012
    299
    547
    West Cornwall
    If you havent got an inline isolation switch then it is better to cover them up. Disconnect the solar first then the batteries. Reverse the procedure when reconnecting. Batteries first then solar input. Hope this helps.
    Phil.
    • Like it Like it x 2
    • Useful Useful x 1
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,253
    8,623
    south shields
    Hi.. should be a straight forward swap... If you don't cover the panel just make sure the wires are insulated and no dander of contact while working... There should be a fuse on the controller to battery side you could pull to isolate that side...
    I think most controllers require the battery side connecting first before reconnecting the panel to the controller. .
    Andy.
    • Useful Useful x 1
