Kon tiki
I fitted a SOG on my last van & found it worked fine. Big benefit was you can empty the toilet at anytime whereas you might be reluctant to empty it if you have put chemicals into it before it is almost full.
Nobody has mentioned the Thetford system on my new van it has the Thetford C-250 toilet with the Automatic ventilator: filter absorbs unpleasant odours, ventilator draws them off to the outside of the vehicle (I asked somebody on the Thetford stand about fitting a SOG & he virtually told me that on the C-250 it is pretty much doing the same job) I think that it works better than the SOG as the fan comes on when you press the button & as it seems to operate on a timer it stays on for much longer than the SOG. It also vents out under the van. If you have the C-250 there is a compartment below the toilet for the fan & filter to be fitted. :thumb:
