SOG toilet kit (1 Viewer)
54mud
100
55
Stone, Staffordshire
Coach Built
24 on and off
Has anyone got a SOG toilet kit fitted? I am thinking of getting one and wanted to know any
pros and cons from users of one.
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Yup.. for me the biggest pro is we use about 1/8th the water and of course it lasts a LOT longer between empties too
Terry
11,932
9,072
Lincolnshire
Can't remember ;)
You can make your own for free,search DIY SOG on here
terry
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Yes &it's very good.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
SOG SOG SOG
Thetford make a electric ventilator that fits the the C260 (and I think the C250) and it's a neater solution that the SOG system.
I'm taking cover as I expect a battering from the SOG fans :RollEyes:
weejohnw
238
84
Richhill
Started August 2008
SOG
Fitted SOG three years ago and I haven't found any difficulties yet.
Less nasty smells, from either you know what, or the chemicals
you don't need as much water (already mentioned)
Don't need expensive thin loo paper
can be emptied into septic tank as no nasty chemicals
Contents of cassette seems to be more runny so easier to empty.
Highly recommended. But then that's my opinion, based on experience, not hearsay.::bigsmile:
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
How does a 12 volt fan mean you need less water and don't need thin loo paper , all it does is suck the stink out when you open the blade and pump it out side for other people to smell, hard hat ::bigsmile:
Terry
11,932
9,072
Lincolnshire
Can't remember ;)
it;s susposed to encourage bateria growth :winky: should be no smells as it goes through a carbon filter :Smile:-no idea about less water mines alway full/filled with Pee ::bigsmile:
terry
Minxy
32,637
66,514
E Yorks
Carthago Compactline
I was thinking the same as you! I have parked next to someone with a SOG and confirm that they can expel the pong to the outside as we definitely detected a nasty niff coming from it, needless to say we moved!
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Does ANYONE actually use the 'proper' paper?
They'll be believing motorhome salesmen next!:Eeek:
freelanderuk
1,018
534
c class
terry
How many people actually change the carbon filter, all the people I have spoken to you have never changed it and some had removed it
Terry
11,932
9,072
Lincolnshire
Can't remember ;)
I change it if it starts to niff,but also if away I would simply revert to the blue stuff if needed.--- Yes we only use Crushele or Andrex loo roll -in fact I am on our last 2 x24 packs of what was Charmin from the garage -24 rolls in van yesterday-so a stock up is now required :thumb:
If anyone sees them on offer in Lidl @ £7.50 for 24 drop me a message I will be getting around 20 packs to replenish the garage ::bigsmile:
terry
Minxy
32,637
66,514
E Yorks
We once bought some of the 'proper' motorhome loo paper when we were 'novices' (it was on offer at the time though!) but then changed to using the basic stuff from supermarkets (2-ply) but I now insist on better quality (3-ply) as I just ended up using more of the basics stuff so it didn't work out any cheaper and also doesn't "do what it's supposed to" quite as well as the 3-ply and can leave some ... er ... nobbly bits ... ladies will understand what I'm talking about!::bigsmile:
weejohnw
238
84
Richhill
Started August 2008
It just takes less water flushed into the cassette to make the stuff in there go more runny. Don't understand how it works, just does.
