Sog fan has stopped working
Discussion in 'Motorhome Chat' started by Branston1080, Aug 25, 2014.
  1. Branston1080
    Branston1080 Funster
    Oct 30, 2012
    54
    32
    Hi all
    My sog fan has stopped working. It was working fine, 2 weeks away from the van and now it's not working.
    Any ideas? Are they easy to replace and how do I do it?
    Thanks in advance funsters!!
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,130
    1,869
    London
    The SOG fan on our Autotrail is little more than a computer cooling motor. It has two mickey mouse electric wires suppling power and negative.
    One of the wires broke due to vibration as they are not supported. The dealer just resoldered the wire and it has been good ever since.
    The motor on the autotrail is located just below where the cassette slides in/out. You can see the fan and supply cables with the cassette out.
  3. Branston1080
    Oct 30, 2012
    54
    32
    Many thanks, I'll have a look.
  4. simplyjimbo
    simplyjimbo Funster
    Sep 5, 2013
    68
    49
    Dordogne, france
    Hi Branston,
    Ours is similar to MikeD's.
    As you slide the cassette out of its compartment, the cable sometimes snags on the wires that supply the fan motor, and so it may be worth checking the cable run. I had to re position ours and make sure it was not binding on the cassette.
    Jim
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,090
    Leeds the one up North
    Typical Sog connection on Thetfords.
    Check the operation of the microswitch on the shutter too
    [​IMG]
  6. Branston1080
    Oct 30, 2012
    54
    32
    Thank you, if it's the micro switch is it easy to replace?
  7. Techno
    Jul 28, 2010
    14,140
    15,090
    Depends how the fitter installed it. It comprises an alumium angle bracket attached with self adhesive tape and the supplied push pin plastic rivet.
    You would have to remove the pushpin, pull out the rivet and shear the adhesive tape.
    Just check the switch first without operating the shutter by taking the cassette out and operating it by hand. If it clicks and the fan comes on then it just needs adjusting so it operates when you operate the shutter.
    [​IMG]
    • Like Like x 1
  8. Techno
    Jul 28, 2010
    14,140
    15,090
    It has been known for some to rely only on the adhesive tape and the consequence of this is the bracket will probably fall off eventually.
    • Like Like x 1
  9. octopush
    octopush Read Only Funster
    Sep 28, 2012
    133
    51
    portsmouth
    What is a sog fan
  10. MikeD
    MikeD Funster
    Dec 21, 2011
    2,130
    1,869
    London
    Not sure what SOG stands for but it sucks the gas out of the loo and exhausts it outside.
    Stops the motorhome toilet ponging (y)
    http://www.soguk.co.uk/
  11. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    Thanks now I know
    • Like Like x 1
  12. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,344
    1,944
    South Staffs
    And about as much use as an ash tray on a motorbike. :whistle:
    • Like Like x 2
  13. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,642
    3,151
    East london
    <---- sits back.. Grabs some popcorn.. And waits
    • Like Like x 2
  14. Techno
    Jul 28, 2010
    14,140
    15,090
    [​IMG]
    The +ve feed (red) is taken from the flush supply and the -ve (black) is used to switch the fan motor via the shutter operated micro switch
    [​IMG]
  15. Branston1080
    Oct 30, 2012
    54
    32
    Thank you Techno 100
    That's a massive help! (y)
  16. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,804
    13,720
    Norfolk
    Didnt know sogs had fans, must be a club :)
    • Like Like x 1
  17. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Most expensive computer fan ever made..
    • Like Like x 1
  18. Gooney
    Gooney Funster
    Jun 2, 2010
    4,766
    7,855
    Flintshire
    Sucks Out Gas
  19. Techno
    Jul 28, 2010
    14,140
    15,090
    Please do come back and tell us the outcome?
  20. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,610
    22,758
    Narrfoook
    No idea what the Autotrail version of a SOG is like, but the SOG kits are nowt like a computer fan.. Unless some weirdo maker such as Compaq has been experimenting LOL !!
    First thing I fit is a SOG when I swap vans.. Would not be without one.. and having been with someone who has not got one fitted this summer, whilst in 35C heat and absolutely no wind, it has more than proved its worth..
    In the end the other party simply could not use their loo unless they emptied it every hour !
    There is also the advantage that you use VERY little water each use, so ( for instance ) our cassette only needed emptying, on average, 2.5 days
    • Like Like x 2
