Soft Floor Syndrome
Discussion in 'Motorhome Chat' started by Tootles, Aug 28, 2014.
  1. Tootles
    Tootles Funster
    Sep 14, 2013
    9,267
    33,249
    Lancaster
    And so, what causes a 'soft floor feel' in a dry van?? Is it the ply de-laminating??? Could understand if the area concerned had been wet, but no sign. Is it just age? It's not a 'problem' on ours, but you can just 'feel' it a bit when walking on the 'infected' area.
    Lastly, a problem to worry about...Or not??
  2. big bertha
    big bertha Funster
    Sep 5, 2012
    1,640
    7,387
    Northumberland
    Was going to say tighten up you pelvis until I read the rest.;)(y)
    • Like it Like it x 2
  3. tambo
    tambo Read Only Funster
    Jun 21, 2014
    875
    637
    Dunfermline fife scotland
    What's the underside of the floor like?
    Often it gets damp from underneath which eventually causes it to soften
    • Like it Like it x 1
  4. simbadog
    simbadog Funster
    Sep 12, 2012
    1,301
    2,187
    Wengen
    Probably just death watch beetle I would imagine :rolleyes:
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,199
    3,028
    Kendal, Cumbria
    The floor to foam glue lets go. It may be affected to an extent by natural dampness but the real cause is that manufacturers have been forced to use eco-friendly adhesive which isn't as good as that used a few years ago. I believe they've resolved the problem with later vans.
    My advice, borne of experience with a couple of caravans, is don't leave it. Because the floor is less rigid where it occurs flexing of the plywood indents the foam, then the plywood stretches, then it indents the foam even more. Eventually the plywood forms humps and dips that are difficult if not impossible to get rid of. There's a simple and permanent fix (DiY if you're up to it) that involves drilling small holes around & across the affected area then injecting pourable epoxy resin with a syringe. It's a job that will take an hour, a days wait, then however long it takes to re-lay the carpet / plastic flooring.
    • Like it Like it x 5
  6. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,290
    16,962
    Liverpool.
    Thats the only permanent way to cure it.
    • Like it Like it x 3
  7. Abacist
    Abacist Funster
    Oct 15, 2013
    1,305
    1,558
    Devon
    I did this on my old caravan which was always dry as a bone and it worked a treat. You can either do it from below or from above and I did mine from above and was glad that I did. I supported the floor from below whilst I did the work.
    Having drilled a matrix of holes in the floor you mix the resin with fixer and then inject with supplied syringe into the holes until the liquid starts to seep from the adjoining holes then move onto the next hole. You then plug the hole with a piece of supplied dowel. When all done leave until set the next day and you then have to use a belt sander or similar to remove the set resin and protruding dowels. The floor is then as good as new and solid as a rock.
    Just remember that the floor is a sandwich of ply, insulation and then more ply. You must only drill through the one layer of ply and some of the insulation - don't go through both layers of ply or your resin will all run out onto the floor and set making an unholy mess!
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    Wonder if it's a Swift stable circa 2005/6/7 ;)
    terry
  9. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    I'm puzzled. The normal resin ( as from Halfords ) dissolves the foam in a Burstner.
    "Choose you next resin carefully Mr Bond".
  10. Abacist
    Abacist Funster
    Oct 15, 2013
    1,305
    1,558
    Devon
  11. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    Watch how you drill as was in local caravan repairers a month or so back and the young fitter was fixing á soft floor except he drilled right through and the epoxy ran out under Neath boss not best pleased !!!
  12. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    True: Apollo Delamination Kit
    Bad to use at that low a temperature unless they say you can.
  13. Tootles
    Tootles Funster
    Sep 14, 2013
    9,267
    33,249
    Lancaster
    Right. I haven't got any foam. The floor is dry above and beneath, with no sign of flexing. As far as I can tell, the floor consists of 3/4 ply, with just the standard lino on top. This is a 1992 Hymer coachbuilt. The soft bits are nowhere near to the hab door, but in two places in the centre corridor, one by the dinette, and one outside the loo door.
  14. tambo
    Jun 21, 2014
    875
    637
    Then there can be only one solution!
    Lay off the pies there's nowt wrong with floor......your just too heavy :p
  15. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    We have 91 Hymer 564, I was worried the floor was delaminating due to the squeaking whenever you hit the same spot.
    Did the bouncing on the spot bit and lifted the carpet but couldn't feel anything wrong.
    I stripped out the heater, rebuilt and refitted it and hey presto, no more squeaks walking past the table or coming out of the loo, and no more feeling of springing as you walk.
    Hymie.
  16. Abacist
    Abacist Funster
    Oct 15, 2013
    1,305
    1,558
    Devon
    Instal some form of joist under the floor to provide additional support
  17. simbadog
    simbadog Funster
    Sep 12, 2012
    1,301
    2,187
    Wengen
    Is there any yellow staining in those areas? :rolleyes:
  18. Tootles
    Tootles Funster
    Sep 14, 2013
    9,267
    33,249
    Lancaster
    What a great idea! Thanks....(y)(y) The front part of the floor is 'underpinned' by the original steel floor pan of the Fiat Panorama parent chassis, so that's not a problem, but I will certainly see if lateral cross bracing can be fitted, using maybe 3x2 timber.
    No Simb, this isn't the same MH you owned........:rofl::rofl:
