Smoking....
Discussion in 'Tech/Mech General' started by Doninpompey, Mar 4, 2013.
  1. Doninpompey
    Doninpompey Read Only Funster
    Mar 4, 2013
    Angus
    Guys van you give advice please,
    I have a 94 Burstner Ducato six berth, she is a lovely van but has now developed a 60 a day Marlborough habit ( smokes all the time) engine starts and revs lovely, but lots of blue smoke and a loss of power. She is the 2.5d engine, I want to keep the van as I love the layout, does the engine need replacing?
  2. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    Sounds like you may have a broken piston ring or worn cylinder bores. Or even a valve problem.
    Blue smoke is normally a sign of burning oil. Have you checked your oil level lately. I would recommend you keep an eye on it.
    If you know a friendly garage near you it may be worth getting them to do a pressure test on the cylinders.
    I'm sure someone else will come up with more answers, but don't start throwing away the engine yet. All is not lost. :thumb:
  3. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    Blue smoke could be worn or stuck injectors.
    Did it go faulty over a period of time or suddenly?
    Does the smoke smell of half burned diesel
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,234
    16,838
    Liverpool.
    Try a dose of Ametech Engine Restorer. Its available on ebay and it works. Its not cheap but within 1000 miles it will cure it if you do exactly as it says on the tins, as long as there are no broken piston rings.
    • Like Like x 1
  5. maacracing
    maacracing Read Only Funster
    Mar 11, 2013
    52
    10
    dundee
    If its a stuck injector it would be black smoke
    If its not a broken piston ring its more likely to be a valve stem seal
  6. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,517
    england
    might be an idea to have a looksee around your turbo for any sign's of oil?
    if there is, your turbo main seal or bearing has gone or going:Sad:
    could also be a blocked engine breather.
    normal way to check if rings are worn is look for back pressure do this by starting engine and remove oil fill cap if its blowing badly it's your rings or blocked breather?
  7. duane0001
    duane0001 Read Only Funster
    Jan 18, 2013
    629
    389
    East Coast, North Yorks
    Blue Smoke
    If the Smoke is to the white end of the scale it could even be steam from a tiny head gasket leak
    My Mazda Bongo did this
    Duane
  8. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    3,994
    6,500
    Roobarb land
    A GOOD diesel fitter should be able to tell you what's wrong fairly quickly
    If you dont know what you are doing and start messing around on your own you could end doing a lot more damage or replacing parts that are ok
    This I speak from experience as a mechanic
    It could be anything trivial or major
    • Like Like x 3
