smoking
Discussion in 'Motorhome Chat' started by stuboy7, Jul 6, 2009.
  1. stuboy7
    stuboy7 Read Only Funster
    Jul 1, 2009
    42
    folkestone kent
    hi everyone, i have 2.5 fiat ducato 91, its smoking a fair bit while accelerating wonder has anybody else had this problem? its done 128000kms but been stood for 2years.:BigGrin::BigGrin:
  2. johnandcarol
    johnandcarol Deleted User
    Might sound a silly question, but what colour is the smoke?
  3. stuboy7
    Jul 1, 2009
    42
    folkestone kent
    the smoke is black and smells like oil burning.:Smile:
  4. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Not water vapour then.....
    Possibly Piston Rings stuck allowing Oil blow-by the pistons.
    Try some Fuel Cleaner.Wynns/stp...Remember the "old" Redex....Did it smoke prior to laying it up?
    Might loosen up/clear after a good run.
    Does it start ok or take some turning like the compressions a bit low?
  5. johnandcarol
    Advice as above, add some fuel treatment, and give it a long run, but check the iol etc first.
  6. bopper19
    bopper19 Read Only Funster
    Jan 21, 2008
    3
    Portsmouth
    simple injectors need cleaning and new filters:thumb:
  7. stuboy7
    Jul 1, 2009
    42
    folkestone kent
    put some wynns treatment that goes in oil filler yesterday. starts first turn of key done about 1500kms since got m/h 2weeks ago. had oil fikter change last week pulls ok but sounds bit noisy. perhaps she is aloud to smoke now she is 18 years old. lol.:Laughing:
  8. gazznsam
    gazznsam Read Only Funster
    May 15, 2009
    273
    Eastwood, Notts
    get the injectors serviced, they prolly never have been and will prolly due replacement now,
    no need for a diesel to smoke except a little puff of black when you floor the go pedal and it's chucking the accumilated soot out the exhaust, but leaving clouds of black smoke behind you aint nice for the person following you, and what you can see in your mirrors will be 5 times worse viewed from behind.
    Black smoke is overfueling btw, dribbeling injectors, poor spray pattern etc,
    blue is oil burning, OR poor combustion if it does it only on start up,
    white is unburnt diesel... or water from a leaky head gasket,
  9. stuboy7
    Jul 1, 2009
    42
    folkestone kent
    thank you all for advice, will start by having injectors checked/changed and hopefully sort out smoking.:thumb::thumb::thumb:
  10. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    sometimes its worth checking out your local diesel specialist independant ask about the one i use is a marvel with all things diesel and most of the local garages use them for injector work etc look in yellow pages
    Diesel Fuel Injection in Kent » Yell.com
    try link and put in your postcode
  11. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Save your self a lot of money, don't go ahead with any expenditure until its been checked out by at least 2 preferably 3 garages. miss diagnosis is easy!
    As a time served diesel fitter but now retired and out of date with modern engines let me tell you that it takes more diagnostic information than you have provided plus stabs in the dark are normally not worth the effort. but if the smoke has oily smell and a blueish colour its probably not your fuel system
    Good luck
    Doug...
  12. stuboy7
    Jul 1, 2009
    42
    folkestone kent
    thanks for that advice found injection specialist in ashford next town to me,:BigGrin::BigGrin:
