Smoke alarm vs Toast (1 Viewer)
Jul 17, 2009
188
155
Doors open, windows open, roof vents to max, still the B smoke alarm screams when we fancy toast for breakfast, have resorted to seperating machine from battery which seems to have done the trick. We now of course face the possibility of becoming toast ourselves with no warning if something electrical decides to fight back. Anyone found a good trick to combat the wailing unit ?
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Use electric toaster outside door on long lead, no problem.
Under van if raining.
Dave :thumb::thumb:
1,622
280
Five Roads Alyth
A class RV
since 2005
Get a toast friendly alarm, and no I'm not joking.
When we (finally) bought alarms for the house, and then the (last) RV we found one's in B&Q, I think, that are designed so they shouldn't go off for toast, cooking, cigarettes etc, and it seemed to work, no false alarms, unlike the one in the current RV which is the origional and like your's, bloomin thing goes of at anything.
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I do believe what you may have got there are heat alarms
Most excellent bit of kit but usually quite expensive.. Will have a rake around B & Q tomorrow :Smile:
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
Found em !!! Brill and a good price too. They are optical ones not heat ones :Smile:
Link Removed
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
We take ours down when cooking and likely to go off.
1/4 turn removes said alarm from the ceiling mount, put it on the table to remind you to replace it once toast is done. :Doh:
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
We fitted one of these.
Link Removed
It has a 15 minute hush button. Seemples
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Our van came with a gas alarm. Bloody thing went off at a sparrow fart (or was that Steph?) So taking it out and using power supply for an outside light. :thumb:
43,323
49,428
Link Removed
we're plagued with the same problem...i usually carry on through it and it resets eventually.
my question is......has anyone found one of these toast freindly ones which includes a carbon monoxide detector.
our current one does both in one unit and it shouts as well
FIRE...FIRE...SQUEAL..SQUEAL..FIRE..FIRE,
WARNING--CARBON MONOXIDE..SQUEAL..SQUEAL, WARNING--CAR......ETC
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
PJ, do not want to burst your bubble but what you have there is a small child nailed to the roof..
Have you never wondered why the battery does not seem to run out ?
43,323
49,428
Mmmm, small child eh !
next time it squeals i'll stuff some of this in it. :thumb:
Link Removed
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Buy one of those small push button light switches. Drill a hole through the side of the smake alarm casing near the wiring from the battery and fit switch. Cut one of the wires coming from the battery and wire the ends into the switch. When the alarm goes off just operate the switch. After breakfast reset the switch. Had one that I modified in our caravan for years and it worked a treat. Probably a good idea to have a pice of bright coloured cord that you can leave dangling when you have isolated the alarm, then restow when you switch it back on.
Something like this:
Link Removed
John
