Smelly water (1 Viewer)
philw111
629
557
Moray Firth
Bessacarr 484
Since 2004
We use bicarbonate of soda. Pour a solution down each plughole and then go for a drive around to swill it about in the tank before emptying.
Phil
Jim
Ringleader
Jul 19, 2007
36,315
130,209
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Any of the above will work. Best thing is to empty it, if an empty tank smells then you really do need to disinfect it. If you can't empty for whatever reason when travelling, keep plugs in your kitchen sink and shower tray and if it is getting a bit wiffy it keeps it out of the motorhome:thumb:
jb0371old
465
408
Norfolk
Autotrail
1 year
you could also upgrade the traps to european ons which work by storing some water in the bottom to stop the smells coming through, just like the u bend in domestic drains, they are called 128108
SMEV 25mm Syphon Double Waste fitting.
as per the Leisureshopdirect website, I got the double one due to the draining board draining into the same pipe
GJH
29,450
38,827
None, now sold
2006 to 2022
I've used Buster Kitchen Plughole & Sink Cleaner when we get home after every trip after seeing a review in a magazine some years ago. Don't pay full price though; Lidl & Aldi have it in their specials list reasonably often so I buy a couple of bottles each time.
I keep a bottle in the van but have never had to use it whilst away. What I have used though, having seen it mentioned several times on forums, is orange cordial (supermarket own brand). A glug of about as much as you would put in a glass poured down the offending plug hole does the trick for some reason. I don't know the science behind it but it works.
GJH
29,450
38,827
None, now sold
2006 to 2022
There's one of those fitted to the kitchen sink in our van but apparently not to the basin in the washroom - it's the latter that does allow odours through if anything.
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
I got a tip from a friend re waste tank pour a 2 litre bottle of coke down the plug holes, on the way back home from a trip after emptying on site etc, the coke will clean all sorts of rubish, I was shocked what came out of mine :whatthe:, then a bottle of good smelling disinfectant to freshen up. Pete :thumb::thumb:
Sep 30, 2008
340
509
A glug of Asda's own brand sterilising fluid every couple of days. Less than £1 for 1250ml.
Put the glug into the waste water thats going down plughole.
If it's safe for babies bottles etc. can't see it doing any harm to a plastic water tank.
We have been using it for four years with no probs ( touch wood ).
If you've got a shiney plughole (new van) I wouldn't advise using it. For those
older vehicles like ours with plugholes that are less than perfect it is a cheap solution to a
smelly problem
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
We have found the Thetford Grey Waste Freshener very effective,and it has removed a black scale which was lining our tank when we bought it (pre-loved). It also increases the empting rate when it starts to slow down.
Mike.
Nov 8, 2010
171
122
France 86
Chausson Allegro
Since 2010
A 2 litre bottle of supermarket cola, only 17p cleans almost anything, use it in the cassette too:thumb:
lorger
9,654
90,482
Dumfries
Knaus Sun 650MEG
we have poured diluting orange juice down our and seems to work, i also always leave the tap open when not in use also on site i tend to empty it every day into bucket and down the grey waste drain.
pudseykeith
382
105
Leeds West Riding of York
6 Years
Bleech, domestos.
After a days use wash out the sink and washbasin and showerer with a solution of water and bleech. you will always have a clean a d sweet smelling gray tank.
PK
chatter
3,689
937
cheshire
5th wheel
It helps in the first place if you dont empty tea/coffee down it if you take milk in your drinks, tip them in a separate container which you can empty at the appropriate point, another thing to cause smells etc is excess fat/oil from cooking once again tip into a container when cool then wipe out the item with kitchen roll before washing.
Both of the above items are the main cause of smells in the grey tank
Apr 29, 2009
2,320
1,991
West Yorkshire...Halifax
Vanless....BUT....!!!!
The Dilute Orange always worked for us any own brand will do....Own Brand sterilising fluid (as in Milton Fluid) is good too..I once used DAZ powder diluted it to around half a cup to a couple of pints of water poured it down each plug'ole..left it for a day when we were touring...sloshing around in the tank...got to a site and dumped it out smelt luvverlee...
village
11
EAST ANGLIA
COACHBUILD
we had this problem if you leave the tank lever open and let it breath between journeys seems to solve the problem
