Smelly air-con (1 Viewer)
X
Xoxoc
My american RV's roof mounted air-con works well in that it cools the van down a treat.
Trouble is, it has a slight smell with it. Best way to describe it would be stale...or fusty.
We've cleaned the foam filter in the ceiling but didn't make a difference.
Anyone got any ideas or solutions?
Chris
21,053
278,728
None
10 years
different deodorant ? ::bigsmile:
May 8, 2010
221
208
South Wales
RollerTeam T-Line785
since 2009
always keep our air con button on constantly for hoy or cold and works a treat with no smell , dont no if it makes a difference :Smile:
43,329
49,444
Hi Ho, Hi ho, its on the roof you go :ROFLMAO:
get up there and take the top cover off......you'll be surprised what finds its way in.
i had an old birds nest, complete with eggs, under the cover when i searched for the source of a leak this winter.
scotjimland
2,324
10,060
A Woosh bang
Get up on the roof, remove cover and clean all the crap out, leaves etc .. also clean the evaporator cooling fins.
beat me to it John :roflmto:
motor roamin
May 23, 2010
1,541
792
Leicester
2 mins
Yup I think its a cleaning job, rotten leaves or the like.
Have fun I didn't :ROFLMAO:
All the best Rick
Wheelie
136
Whitehill Hampshire
2nd year
You need to go to an HRP or Climate centre and buy some coil cleaner, i cant off the top of my head tell you the make but if you go to one of these suppliers they will tell you. remove the filter and wash with clean soapy water, remove what panels you can to access the evaporator coil and spray the coil cleaner all over the coil leave for 5 mins the spray with clean water to wash off, that should clear your smell, if that fails buy a smelly jelly from the same supplier and stick it up behind the filter.
Hope this helps
Neil
rainbow chasers
3,680
1,725
Mid Cornwall
Various
You can buy an air-con deodorisor from most car shops or motor factors.
To use, you run the car, put the air con on and after a few minutes, set the can off, shut the door and run!
(a bit like those smoke bombs - only they smell nice)
The car draws it through the system, and before you know it, strange women will be banging on your windows trying to get in.
There are a range of different fragrances to choose from:
Runners' Armpit.
Soldiers' Boots.
Athletes' Foot (but I think you have that one)
Cricketers' Box.
:ROFLMAO:
I am not sure if they come in flavours - but it is around ÂŁ5-8 a can!:winky:
1Oll
175
86
Cheshire
A Class (German B Class!)
6+ years
We had a similar problem with our aircon in our photographic studio. The man who turned out to service it asked if we had some Dettox spray. He switched the aircon on and sprayed the Dettox into the inside air intake. 5 minutes later it was perfect and 10 years later still no problems. had the same musty smell from my car, similar treatment. Perfect again.
Regards Brian.
1Oll
175
86
Cheshire
6+ years
Regards Brian.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
sounds like something dead on top
I suspect Brian being in the hot weather so long you have a few dead lizards rotting away in the cowling.. or something else dead that is causing the pong.
Bob:Eeek:
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
It's got to all those caterpillars Bryan, that's why you havn't seen many, they are all living in your Air Con.:ROFLMAO::ROFLMAO::ROFLMAO:
7
7735
My aircon smells sometimes I just have to shut the door and windows.
spongy
