Smell From Trauma Boiler
Discussion in 'Motorhome Chat' started by chasthedagger, May 27, 2015.
  1. chasthedagger
    chasthedagger Funster
    Apr 28, 2008
    82
    20
    rayleigh, essex.
    Does anyone get a smell from their trauma boiler ours smells like plastic getting to hot, we had a new pcb fitted 18 months ago and the place that fitted it tested water temps and both 40 and 60c were within tolerances and checked for overheating.
  2. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,801
    yes.... we get that from ours when heating water only. It has done it since new (2 years ago)....... works ok tho'
  3. fastpat
    fastpat Read Only Funster
    Oct 15, 2013
    481
    935
    County Durham
    Not had it, but have read elsewhere that it relates to bends in the piping being too tight / close to the boiler. Trauma technical department are very helpful.
  4. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    Ours does it too, although not all the time. Seems to be on water only, and when set to 60, but then not always. I suspect - but am not sure - may only be on electric.
  5. Speve
    Speve Funster
    Jul 29, 2013
    2,191
    1,886
    Salisbury
    Our FB Tracker had strong smell occasionally discovered that the ducting near the boiler under the fridge got really hot and the smell was coming from outlet it fed by the door never discovered cause and have since parted with van in favour of a Hymer A class
  6. Adbt
    Adbt Funster
    May 19, 2015
    597
    901
    Cheshire
    Have had the same , weird or needs investigating? Thoughts from the experts? Cheers !
  7. Steve
    Steve Funster Life Member
    May 8, 2013
    1,589
    1,875
    Compton Berkshire
    when heating water only on electric only very little airflow so will get hot.
    Steve
  8. chasthedagger
    Apr 28, 2008
    82
    20
    rayleigh, essex.
    Ours is in a hymer and it does it when heating water 40deg on gas.
  9. Tinty
    Tinty Funster
    Mar 29, 2015
    53
    57
    Darlington
    Ours does this and seems to be if it's on 60 setting. Also in a Hymer, I've found if I keep it at 40 it doesn't seem to happen (n)
  10. Gromett
    Gromett Funster
    Feb 27, 2011
    8,189
    15,031
    UK
    Worth investigating. Maybe nothing but if not you want to find out?
  11. kelv
    kelv Funster Life Member
    Jun 23, 2014
    343
    274
    leicester
    I have a hymer it smells when hot water is on high not sure why thought it was because the boiler is new but after reading these posts not sure
  12. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Yes !! Then we know it's ready for us to shower (y)
    • Like it Like it x 1
