Smashed Aerial
Discussion in 'The Beginner' started by Zigisla, Feb 15, 2016.
  1. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,079
    1,269
    Fareham, Hants
    Driving on a very narrow road over the weekend and had to move over for an on coming van travelling a bit too fast for my likings. Anyhow, as the side of the road was flooded, I had to venture into these puddles, but unfortunately this was a ditch and not the side of the road. This made me slide off the road and suddenly BANG, I looked in the mirror and all I could see was a branch clattering down the side of the MH. I didn’t even consider looking up before moving over left as I was only concerned with my wing mirror. I stopped but couldn’t see any damage, so continued on to the Forest Camp site. When I went to raise the Aerial, I noticed that the H / V indicator was not facing forward in the stowed position, so had a closer look and the impact must have spun the Aerial around as I can see one of the Small telescopic aerials has smashed off and split the area around the actual 550 Aerial. Now I don’t need beating up any more than I have done to myself already, but need to know if I can
    1. Repair this area and with what
    2. If I leave a hole, is this area water proof i.e. can water enter the MH via the hole and mast
    3. If I need to replace the aerial, can I replace just the 550 part or does it come as a complete set i.e. aerial, mast and controller for pounds many?
  2. SandT
    SandT Funster
    Oct 15, 2012
    127
    384
    Malta
  3. Badknee
    Badknee Funster
    Aug 25, 2014
    3,712
    15,971
    notloB
    Bugger! I would climb up and if you can get the aerial down to ground level to have a better look see first of all. If I'm right it does radio and tv and if your lucky it's the radio bit that's damaged and you might be able to replace the damaged bit with something else like a coat hanger but deffo get it sealed up with something quickly with our weather at the moment. Good luck. (y)
