Smart car trailer tyre pressures
Discussion in 'Tech/Mech General' started by Wicketter, Jul 1, 2012.
  1. Wicketter
    Wicketter Funster
    May 30, 2012
    196
    137
    Bristol
    We have a trailer we use for towing our Smart car behind our Bailey Approach 740. The tyres are marked 155/70R 12C, the trailer was from smart-trailers.co.uk. We think they should be around 4.5 bar, can anyone help with this please ?
    Many thanks.
  2. Brian and Jo
    Brian and Jo Funster Life Member
    Sep 24, 2007
    2,302
    4,531
    oswestry,shropshire
    Smart
    Hi there the tyre pressures on the 155/70/12 trailer tyres should be between 80 & 90 psi:thumb:
    regards brian jo and josh
  3. Wicketter
    Wicketter Funster
    May 30, 2012
    196
    137
    Bristol
    Tyre Pressures on smart car trailer
    Many thanks for the speedy reply. 90 psi seems really high for a load of 750k ( The Smart Car) we have just got back from a trip and checked the tyres which were 3.5 bar which seems too low ( they looked a bit squashy to me!) Sorry not very technical and I get confused between bars and psi's. 90 psi's would that equate to 6.2 bars ?
  4. chesterfield hooligan
    chesterfield hooligan Funster
    May 12, 2009
    1,048
    506
    Stanton Hill
    :Smile: a lot of modern tyre's will have the tyre preasure on the tyre loaded and unladen :Smile:
  5. Brian and Jo
    Sep 24, 2007
    2,302
    4,531
    oswestry,shropshire
    smart
    hi there yes that is correct 90psi is 6.2bar.the tyres on your trailer are hopefully not ordinary car tyres but are proper high pressure J-rated trailer tyres,manufactured to operate at high pressures, if you do not maintain the pressures they will get very hot when in service..also make sure that they have metal high pressure valves fitted to the wheels and not ordinary rubber car valves.
    brian jo and josh:thumb:
  6. Wicketter
    Wicketter Funster
    May 30, 2012
    196
    137
    Bristol
    Tyre pressures
    Once again many thanks. Really useful info, the tyres are fine but we will have metal tyre valves fitted now and than pump them up!:thumb:. We are off to France in 2 weeks so needed to get it sorted asap.
    • Like it Like it x 1
  7. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,315
    731
    Darlington
    My Bantam Smart Car Trailer (Tyres 165R30C) has a plate attached which states 65psi.
    John
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,923
    YO11 2BD
    If anyone should know it's Brian (brianjojosh).
    he's a respected tyre dealer/fitter.
  9. Brian and Jo
    Sep 24, 2007
    2,302
    4,531
    oswestry,shropshire
    Hi john,yes in a 165/13 65psi is correct but a 155/70/12 J rated trailer tyre is designed to run at between 80 & 90psi.it is designed as a semi low profile tyre with a very strongly constructed sidewall,hence needing the high pressure,and can only be fitted to trailers.the tyre on your trailer can also be fitted to some small vans and some caravans:thumb:
    brian
