Smart Car Pulse - Can it be Towed?
Discussion in 'Motorhome Chat' started by StitchUp, May 20, 2013.
  1. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Bridgend, South Wales
    Just a shot in the dark!
    I've been offered a Smart Car Pulse - would anyone know if these cars are suitable for towing?
    John
  2. Spenders
    Spenders Read Only Funster
    Jan 19, 2013
    398
    362
    Tadcaster
    As far as I'm aware the Smart has an automated manual gearbox, so should be capable of being towed (cos you can put it in neutral!).
    Knowing me as I do however (and my lack of specific knowledge!), I would recommend that you ask a dealer or check their website etc to get the definitive answer!
    Simon
    :thumb:
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    ignition on, select neutral, ignition off.
    just selecting neutral on the selector lever isnt good enough as its an electrically controlled box and needs electrical power to move to neutral.
    without power the lever will show neutral, but the box is still in drive.
    i believe the key cant be removed unless in park so you need another key to lock the doors...even on an A frame
  4. duane0001
    duane0001 Read Only Funster
    Jan 18, 2013
    629
    389
    East Coast, North Yorks
    I've had two smarts, yes they can be put into neutral and towed but like Papajohn says, have the ignition on to put it into neutral, also there is no park on a smart and once in neutral the keys can be removed and the doors locked :thumb:
  5. pappajohn
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    i stand corrected on the key issue...thanks :thumb:
    But does removal of the key not set the electronic steering lock ?
  6. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,604
    22,714
    Narrfoook
    intersting point that.. I have had countless smarties and every model bar a crossblade but have no idea if the steering lock activates with the key removed.. I shall test it tomorrow !
  7. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,066
    13,081
    Ramsey, Isle of Man.
    According to Smart, they can be towed for a maximum of 30 miles, at a maximum of 30 mph.
    Your choice.
    Craig
  8. My Dog Likes Fishing
    My Dog Likes Fishing Funster Life Member
    Dec 16, 2012
    289
    230
    Lancashire
    I have a Smart car that I tow all over the country. I bought it from a motor homer that had already had it converted. I just put it in neutral with the ignition on and then switch ignition off.
    It tows superb but I've got to admit the steering lock has never been a thought. Maybe it is disabled when the car is wired for towing.
  9. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    That is the correct generic answer to
    "Can I tow an Automatic":Doh:
    As already stated The Smart is not an automatic, but a manual that has been automated.
    A huge technical difference:thumb:
    Smarts have been sucsessfully towed for hundreds of thousands of miles
    There have been disasters caused by human failings in selcting neutral incorrectly
    G
  10. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    I towed mine for hundreds of miles, if not thousands. There is no steering lock on a Smart.
  11. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Thanks guys, all very positive.
    Last year I purchased a Car-A-Tow 'A' frame, it had been used with a Fiat Punto.
    I'm guessing that if I purchase the Smart Car I'll have to get it modified to take the frame and maybe some bespoke parts for the frame.
    Anyone got knowledge of what's involved and cost to get the car done?
    John
  12. davejen
    davejen Funster
    Aug 21, 2008
    1,260
    715
    Kirkpatrick Fleming Dumfries
    Ihave also towed a Smart, unfortunately , although I had put it in neutral and switched the ignition off it STAYED IN GEAR this was because I HADN'T PRESSED THE BRAKE PEDAL this actually completes the circuit to enable neutral to be selected. So make sure you push the brake pedal,AFTER selecting neutral.
    Hope this helps avoid any problems for you, .
    Cheers, Dave:thumb:
