Locksmith
I agree, they did the demo, set up and the checks I watched and checked the neutral was selected and the hand break was off I put the bungee on as he showed me and then he did all the final double checks as I'd not done it before, I was told not to worry, when I do it on my own I will be fine if I follow the list of procedures printed on the A Frame, that was the last time I went in my car.... I then did three towing circuits of the large car park breaking hard about 6 - 7 times but after the first circuit and braking it seemed hard to pull away! the engineer was no where in sight so I carried on around the car park braking and pulling away doing another 2 circuits he then appeared and waved me over and directed me to a stop in front of the main building much to the annoyance of the other workers as I was blocking the big doors and they was trying to put trailers away ready for the Royal Holiday break. I got out and told him it seemed to drag when pulling away but he said I was not used to towing the car on the back and I needed to give it more welly, he then tightened the A Frame cable went in the car and checked and pulled the bungee.. he asked if I had any spanners and said I should check the cable tension 2-3 times on my way home, he then shook my hand and said good luck and goodbye...... It seemed a very short time later we then stood on the side of the A1 helplessly watching my Smart Car burn having saved the Motorhome.Sorry to hear about your Smart car and hope you get it sorted out soon.
We have an Armitages aframe and tow a Ford Fusion and had no trouble with it as yet (touch wood) when I had it fitted I only took the car up to their place and done the adjustments myself when I got home, which did take a little while to get perfect, even now when we are using the aframe I always check that the brakes are not binding on the car several times during the first 20 miles or so and whenever we stop for a break.
