Slow drain away (1 Viewer)
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
From shower to waste tank.
I have tried everything including two sets of drain clearer over night and endless boiling water down it..........
It does drain away not bot fast enough and slowly fill shower tray if you use kitchen or bathroom sink..........:Sad:
Tried to buy a plug for it but cant get a small enough one to fit the shower drain..........
Tried a wire up from tank but to scared to push hard.
Dealer workshop been great so far, new complete toilet and then new water pump not even blinking an eye.
anyway
Ideas???????
Road Runner
Road Runner
1,143
1,445
Europe
yes
Hi John only options are re route pipes or buy a small plunger :winky:
terry
Tried plunger but no surface in sinks or shower tray to get seal.........:cry:
Other option scary for me..........
try and get someone to do it along way but try for plug till I can do it, must find old still ironmonger to sort one.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Normally its a mixture of hair and soap that builds up in the grooves of the flexypipe but on your camper model the pipes are solid plastic similar to a house. So this should not be a problem. If you have tried drain cleaner without success then I would also suggest checking the routing of the waste pipe to see if there is enough fall on it. If you can find one of the small wire drain clearer's usually sold at the cheap shops these are very effective if used from the plug end,not the outlet end.
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
roll or squash a dishcloth up and use that as a plunger forcing it up and down 5/6 times :winky:edit forgot to say do it when sink/shower trays are half full
terry
steveclecy
880
580
Wirral
Since June 2009
Sounds gross but what about feeding in a small flexible tube like those used for syphoning home brew and blowing as hard as you can? May just loosen the blockage?
Steve
Road Runner
Road Runner
1,143
1,445
Europe
yes
Drain cleaner so strong burnt my hand..........well what else would you expect:Blush::Blush::Blush:just minor bit did it........dangerous stuff.............
May be be angle at present but only slightly out...........:winky:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
It sounds like the only option is to re route or re new the pipes then :cry: on the plus side if it is the solid type pipe once you are under the van it is a nice easy jobby :winky:
terry
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
I like the sound of Brian's jet wash ::bigsmile: remember to put an old cloth over the drain holes :ROFLMAO: I fear you will still have to reroute the pipe :winky:
terry
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Stick ramps under the appropriate wheels to see if extra fall works, if it does then you are plumbing rather than un-blocking
Road Runner
Road Runner
1,143
1,445
Europe
yes
Cheers all.......
TDH piccy of my baby, not the best one as taken from my phone
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
It may be a trick of the camera or it may be what i was saying-----water is ever so reluctant to run up hill
Road Runner
Road Runner
1,143
1,445
Europe
yes
Well this has me stuffed at present, I am no DIYer and ground here drenched. Got soaked getting caravan home...............:cry::cry::cry:
nucs200
64
26
UK
a class
a while now
Hi whats the layout on your tabbert, is the boiler in the cupboard next to the back of the shower if so pull the air vent/grill off directly below boiler cupboard which will give access to waste pipes also lift the floor panel over tanks for more access you should be able to tell which waste pipe is which one from sink and one from shower if you feel confident you can cut into pipe (28mm) and use rods or any thing that will act as such and work each way or try sending flexible rod up from waste tank first then buy 28mm straight joint to connect ends together again these joints are only push fit in ffb,s hope this makes sense to you.I have repaired my ffb waste pipes in the double floor which was difficult but doable hope this helps :Cool:
Road Runner
Road Runner
1,143
1,445
Europe
yes
It really help as my model......
Oct 2, 2011
864
571
Scotland
Since 2011
Some basic rules of plumbing. Air bubbles go up. Water runs down . Shit sticks. If its not a blockage it's a replumb. Sorry.:cry:
champers
4,224
8,456
Skegness, UK
Frankia i650 FD
Since March 09
Cheers all.......
She is lovely inside too ... a real beaut and so much space inside, and looks like she has been well cared for .. my John says also well maintained in other corners
Thank you for letting me have a peek inside :thumb::thumb:
Wishing you many happy miles in her (I say her as she is so lovely x)
Kath x
wasp
1,724
18,180
Warsop
None gone caravannin
Hey John I got a pump plunger it`s like a bike pump with a plunger cup on it you run water down the drain and stick the sucker on and pump, it sucks and blows an shifts most crap , failing that it`s a re pipe:thumb:Link Removed
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
If the fall is OK and its just a blockage I have one of these plungers that you can borrow.
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi John where are you now ? I know you have a ferry booked shortly,so this needs sorting quick :thumb:If we have any members nearby they maybe able to offer assistance. ::bigsmile::winky:
terry
joggerman
139
6
Lancashire
Just Looking
Since 2004
Airlock prevents draining.
I had the same problem on a "Geist Spirit 560", which I think comes from the same stable as Tabbert.
It would drain very very slowly. Nothing would shift it. Using a plunger would start it off, then it would quickly drain.
The problem I eventually found was that the clueless van builders had routed the drain pipe up over the edge of the waste tank then down into the waste tank, causing a perfect location for an airlock.
I re-routed the pipe and solved it.
Road Runner
Road Runner
1,143
1,445
Europe
yes
Kath x
My visit cheered me up no end when you both were so positive about my baby.......
Might be asking John if he can have a look at my pipes in his pit?
Really nice to have such lovely Funster's living so nearby as well (for Wales nearby that is:winky::roflmto:)
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Come on funsters we must have some DIYer to help John in Wales ::bigsmile:-------------Workshops are closed for hols :Smile:
terry
