Sloping Drive (1 Viewer)
Jan 19, 2012
628
612
Leicester
Since 2012
First time post, first time motorhomer. We've just bought a used autocruise Starburst, and are still enjoying looking at it! But parking is an issue. We were looking at putting it in gold secure site nearby, but have found that it actualy looks ok on the drive - certainly better than the commercial vans owned by some of our neighbours. We want to take a tandem bike and solos on the rack, which wouyld certainly be easier to manage if it was parked on the drive. Also nice to think I can hook the mains up whenever, open windows etc. BUT it's a steeply sloping drive.
I've just checked iu out with a spiirit level and ruler, and it comes out between 10 an 15 per cent slope. At the moment I'm leaving it in gear with handbrake on, but don't want to do that for long. Also makes the hill starts slightly nerve-racking as the back of the van is pretty close to the house...So, question - would I be safe to leave it chocked, in neutral and handbrake off? These rubber chocks at [ame]http://www.amazon.co.uk/Rubber-Wheel-Chocks-2-0kg-Pair/dp/B000RUBKFW[/ame] seem tough enough - does anyone have any experience of the problem?
Any help appreciated.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
hi
not too sure but you could use levelling ramps under the front wheels to actually level the van then put the rubber wedges under the rear wheels so then you have all 4 wheels chocked as it were.
if possible maybe fix the rubber blocks to a piece of wood that the wheels sit on to make it harder to kick the block out. then it doesn't happen accidentally.
Jim
Ringleader
Jul 19, 2007
36,191
128,620
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Get some large chocks under the rear wheels and reverse on to them. Your van will be happier and your hill start easier. :thumb:
Carol
14,044
111,448
North Wales.
Welcome to Motorhome Fun, on many camp sites our van has to be up on the ramps to level if off and we put chocks behind the wheel, and that is when we are in the vehicle moving around all the time, check the ramps and chocks out on any of the Motorhome sites to see what I am talking about
We keep our van in front of the house a tight squeeze but the longer its been there the easier it seems for OH to get out, and yes it is very convenient to keep it at home. :welcomefunster:
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
FWD will come out backwards better, unless you are blessed with a juddergate machine.
In forwards, up ramps and you'll fly out.
Agree with handbrake off otherwise a good chance it will stick on. But if reversing out they would be best to unstick the handbrake.
398
484
West Sussex
Lowline
Since 2011 therefore I'm not a newbie anymore
I have exactly the same problem!
Would it be better to reverse it down the slope and have cab at top of drive (top of slope) or drive it straight in and then reverse up the slope?
Not tried reversing it out s it is on a Fiat 2.3 chassis and heard they have high reverse gear?
Bob
E
Jan 19, 2012
628
612
Leicester
Since 2012
Thanks for the amazingly prompt replies - think I'll invest in the heavy duty chocks, reverse on to them and see how I feel about taking the handbrake off! I'll be leaving it in gear, and so chocks plus gearbox should hold it.
As for driving in cab first, then reversing out on to the road - wouldn't do that in a car, never mind a motorhome...
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
I used a large piece of timber about the same size as a railway sleeper,no problems with rotting as it was well pressure creosoted for its former use.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Bob
When any vehicle accelerates weight is transferred to the rear, since there is too little weight on the front of a MH anyway, a FWD gets wheelspin all too easily.
But reversing, a bit of weight is transferred to the front, so aiding a FWD vehicle.
With FWD you can sometimes get out of trouble on a soft surface by reversing.
golly
2,001
69,092
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
:welcome: Our drive is on a slope, not quite as steep as yous. I chock all 4 wheels and leave handbrake off and out of gear no problems.
cheers John
1,194
804
Essex / central France
Hymer Star Line 680
9 years
I would not be unhappy on that sort of slope with only in-gear and chocs but like the idea of having a MH at home.
Why not do a belts and braces type of thing and have a large eyelet concreted into your drive, a chain to the tow bar or tow eye/chassis, padlocked together so a theft deterrent too.
That way if there is a little slippage maybe due to high winds you know the chain will take up the slack and hold it.
beachcaster
3,044
3,161
east sussex
a few years
You also mentioned charging it thorgh ao open window.......why not get your local sparks to put a weatherproof point on the outside wall you could leave it plugged in when ever its home.
I also just fitted yesterday........a vanbitz battery management box (Inside the motorhome) which keeps your vehicle battery charged from the leisure battery when it is fully topped up.
Huge benefits to keep your motorhome at home with you if you can.
good luck
barry
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
The only downside is that your fridge won't work on that sort of slope.
You'll need to make sure your food is extra cold and put it in just before a trip!:thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
err actually he did not, there was mention of ease of charging,[HI] and[/HI] opening windows etc. hee hee.
I also would be happy parked on chocks never a good idea to leave the handbrake on for any length of time, it always ends up jambed on.
4,797
42,743
Cornwall Gorran Haven
T Line 785
motorhoming since 1979
Hi, Mine's parked on slight slope, I have drilled in to the concrete and then screwed large chunk of wood down (to act as the chock) after measuring ,so it serve's 2 purpose's stopping it moving and also when reversing in it ensure's that I stop in exactally the right place without hitting the garage . Terry
E
Jan 19, 2012
628
612
Leicester
Since 2012
Many thanks for the suggestions. I've now bought a couple of 2kg rubber chocks, and the van is currently sitting against them on the rear wheels, in gear, handbrake off. Next week I will buy a railway sleeper, put it on the drive as a rear wheel stop, and place the chocks against the front wheels. Belt, braces and piece of string!
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
Buy a length of 3x2 inch tanalised timber(wont rot) width of van, lay behind rear wheels on drive in position you wish to park, drill and raw plug to drive,this will give you position to reverse upto slowly, will stop van going further towards garage and as extra security you could then place chocks behind front wheels, You would also find that you will be able to run over this to enter and exit your garage without to much trouble.You will then when your ready to leave simply need to remove front wheel chocks and drive away without fear of rolling back, has been working for me for 15 years at my mothers home and her drive is at least 30 degrees, very steep. on my own drive which has about the same slope as yours i use same method but not screwed and plugged but simply long screws through wood sticking out that locate into spaces between sets on drive
we are then able to move these about to park vehicles in different places as of when.
railway sleeper is total overkill and you will get sick of moving it, to access your garage, when needed
Hope this helps
Regards
Steve:thumb:
E
Jan 19, 2012
628
612
Leicester
Since 2012
Good point re sleeper, but we should never have to move it. We don't have a garage and the van is parked on the 'forecourt' in front of the house. And so the sleeper will either have the van on top of it or we'll be away somewhere. Also just had the drive tarmaced and Mrs ericonabike would be less than pleased to see me drilling holes in it...
1,710
617
The world
Small car
I've just checked iu out with a spiirit level and ruler, and it comes out between 10 an 15 per cent slope. At the moment I'm leaving it in gear with handbrake on, but don't want to do that for long. Also makes the hill starts slightly nerve-racking as the back of the van is pretty close to the house...So, question - would I be safe to leave it chocked, in neutral and handbrake off? These rubber chocks at http://www.amazon.co.uk/dp/B000RUBKFW/?tag=mhf04-21 seem tough enough - does anyone have any experience of the problem?
buy or make two /four wheel chocks to put behind each wheel you can then park in gear with hand brake off.
you could put a land mount in to the ground and attach a steel wire to the ground mount to the motorhome and tighten up so as to hold the van in place and an extra back up for piece of mind
