Slide-out bed problem (1 Viewer)
jennymaywright
95
5
Shropshire
Low Profile
Hi everyone. We have a 2001 Autocruise Stargazer which has two side bench seats that slide to the middle to meet up and make the bed. A problem has developed with one of the slider mechanisms and it won't slide in correctly. We can't find any instructions anywhere as to how these sliders work and consequently/hopefully fix it. Can anyone give us an idea as to how this might work or point us in the direction of downloading/obtaining some instructions to help us? :Smile:
Terry
11,921
9,022
Lincolnshire
Can't remember ;)
Hi not much idea on your model but most simply run on nylon runners (like drawer type) check to see if one side has jumped the runner and that no small objects have fell into the runner causing it to jam --other things like a lost/fell off wheel etc you should be able to spot :winky:Some may run on ball bearings and these somtimes come out causing jamming so look on floor for small BBs
terry
19,681
51,806
uttoxeter
ambulance conversion
50 years
On mine though not the same van as your , it's just slats that slide between each other if they come loose they can catch the bottom, just want a screw in have you had the cushions up and had a look
J
jennymaywright
95
5
Shropshire
Low Profile
Hi, these are metal runners where one piece slides inside another with ball bearings running between the two edges. When comparing the two runners on the bed, one of the inner pieces seems to be sliding up before it should but we can't really see what's going on. Not easy to describe - sorry :Sad:
TheBig1
17,575
42,950
sounds like a bearing has dropped out or the bar is bent. all I can suggest is carefully strip it down, check, repair and rebuild with silicon lubricant
durhamahoy
241
116
Durham
Since 2011
Hi Terry,
Due to 'over enthusiasm' I also have managed to break the 3 slides on the pull out bed.(Passenger side)
Have looked at o'leary's site but can't see anything suitable.
Was the original problem ever sorted? I'm not sure where to go for spares as Autocruise are now owned by another company. Any help or advice is much appreciated.
Steve the inadvertent motorhome breaker
:Eeek:
Terry
11,921
9,022
Lincolnshire
Can't remember ;)
Hi O'learys bought all autocruse spares --best to ring them and ask for Darren -no doubt they will have something suitable :winky: they have thousands of spares not on the web site
terry
durhamahoy
241
116
Durham
Since 2011
Hi Terry,
Will phone them tomorrow.
Many thanks for the reply
:thumb:
Steve
