Sky TV cant get it to work
Discussion in 'TV & Satellite' started by Bluemooner, Jul 19, 2012.
  1. Bluemooner
    Bluemooner Funster Life Member
    Mar 30, 2012
    1,287
    1,721
    Ribble Valley
    Not having a good day thought i would take my sky box with me for the first time so i fixed it up and cant get it to work, what am i doing wrong i have it pointed the same way as the other Sky dished and nothing, do i have to change any cables on the Vision plus amplifier?
    Andy
  2. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    You will have to search VERY SLOWLY until the signal is on the box. Go to Sky remote services press 4 then 6 and check you have the signal.
    If you are aligning your box by looking at others, make sure they aren't foreign as some could be watching Astra 1. :RollEyes:
    I should have asked where are you first? :Doh:
  3. Bluemooner
    Mar 30, 2012
    1,287
    1,721
    Ribble Valley
    North West England
  4. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,772
    8,014
    Why are you mentioning the vison plus amplifier ?.. thats for terrestrial Tv.. nothing to do with satellite...
    Explain more on what your using and setting up, see if we can help...
  5. Bluemooner
    Mar 30, 2012
    1,287
    1,721
    Ribble Valley
    Tonka its a Maplin £39.99 cheap dish plugged into the side of my van, from the inside of the van into sky box, i have given up for today a cury and a bottle of wine made me give in
    Andy
    • Like it Like it x 2
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    :BigGrin::Rofl1::BigGrin: reminds me of a few yrs ago when I bought one :BigGrin: Took me about an hour before I got it right then my mate moved the dish about an inch and said find the satellite again :Sad:Half hour later and success again :thumb: so he moved it yet again :Doh::cry: Took me hours every time -took mate 30 sec to 60 sec :Doh::BigGrin:Long story short I got my money back and do without sat tv :Wink:
    terry
    • Like it Like it x 1
  7. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Not quite as precise as I hoped but if you go to Dish pointer & put your place name in then select Astra 2 from the drop down list you will have the co-ordinates , compass bearing and elevation (maybe marked on your dish).
    Clearly a compass will be a help. The most difficult part is the elevation ( the angle of the dish pointing upwads. In the UK (North) the dish will be just about vertical and may look as though it's pointing at the horizon.
    A good reference site is http://www.satelliteforcaravans.co.uk with lots of help for your first time try.
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    8,056
    10,412
    If your struggling to get a signal, rule out the connector on the side of the van by plugging the wire from the dish directly to the sky box. Then either tune using
    the built in signal test Services button on remote then 4 then 6 or make life easier with a cheap meter for under £10.
    Getting the dish lined up is hugely different to a aerial, as you either get a good signal or nothing. first make sure your elevation is correct, up and down for your chosen satellite. then swing the dish very slowly left to right, assuming your pointing in the generally right direction. you will most likely pick up a signal which gives you no channels, but dont panic, this means your pointing at the sattelite next to the one you want, just move a little more to the left.
    most importantly though, move the dish vvvvvvvvveeeeeeeeeerrrrrrrrrr(y)(y)(y)(y)(y)y slowly, as the sky box takes a couple of seconds to react
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,382
    18,067
    YO11 2BD
    and there lies your problem......
    the vision plus amp is for terrestrial TV (through an aerial)
    the satellite dish should be connected to your sky box directly.
    pointing the same way as the other dish's isnt quite good enough....it MUST be pointing DIRECTLY and ACCURATELY at the satellite...not somewhere near.
    1/2" out on the alignment means no signal.
  10. tonka
    Jul 2, 2008
    5,772
    8,014
    I think you have some good advise already mentioned.. Go straight from the sat dish to the sky box. Move dish very slowly, it does take practice....
    A common mistake is to set the angle of elevation on the dish as stated in the instructions but you may not be on level ground so that will alter that angle.
  11. Scout
    Scout Funster
    Apr 4, 2009
    3,462
    9,877
    doncaster
    dont just rely on the elavantion markings (if any ) on the mounting braket, make sure your level or it will be out!! at the bracket and you will have to take that into account.
    The elavation is hardest to master for new users, but is VERY important to get it right or you will be messing about forever
  12. JJ
    JJ Funster
    May 1, 2008
    15,122
    27,222
    I wouldn't even get the dish out of its box to start searching for the satellite without a Sat Finder thingy.
    I have a Zenhander (?) from Road Pro...
    As an added bonus to making the quest easier, the beeping noises from the sat finder annoy the people next to you... The same ones who woke you up so early...
    JJ
  13. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    I have a professional sat meter...
    I understand these things...
    I'm in the North West too...
    Now, if you are 5 miles or less away I'll come and help...
    Where are you?
    :BigGrin::BigGrin::BigGrin::BigGrin::BigGrin:
  14. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    There is a app you can have for free on your phone.
    It points in the sky where the sat is, relative to the image on your phone screen :thumb:
