Size of Heater for Storage
Discussion in 'Motorhome Chat' started by Clickem, Dec 10, 2015.
  1. Clickem
    Clickem Funster
    May 20, 2014
    253
    152
    Northumberland
    We are over wintering the van at home, with EHU and an occasional ride out. I wanted to put a tubular electric (greenhouse type) heater in, to use when needed, on cold days/nights to keep the temperature from dropping too low
    The van is a modern 2 berth of 6.25 metres. From your experience which heater would be best to use - 45W, 80W, 135W or 180W
  2. scotjimland
    Jul 25, 2007
    28,934
    25,601
    in my experience, not required.. so don't use one.. but I drain down between trips ..
    I'm guessing you don't and want to protect from freezing ?
    if so a lot will depend on the ambient, 180 watt will barely keep the chill off..
    safer to drain down..
    also be aware.. as low as the fire risk is, portable heaters are not generally covered by your insurer
  3. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,641
    3,149
    East london
    We use ours throughout the year. It's never drained and when it's parked on the drive we leave a oil radiator on inside. It's always nice and warm and ready to go.
    • Like Like x 1
  4. Bill and Shell
    Bill and Shell
    Nov 10, 2015
    48
    17
    Cornwall
    What size (kw) oil radiator do you use?
  5. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,971
    12,355
    under a wand'rin' star
    I may be being a bit thick but, if you're on EHU why not use the moho's heating system?
  6. Augusta08
    Augusta08 Read Only Funster
    Aug 25, 2015
    59
    36
    Morbihan
    I used to over-winter mine with just a de-humidifier running, it creates about 200w of heat when running, probably only about 80/20 duty cycle. HTH
  7. Clickem
    Clickem Funster
    May 20, 2014
    253
    152
    Northumberland
    In my mind, the difference is, that if I use a small greenhouse type heater I know what Wattage I am using, ie 45W, 80W, 135W or 180W
    If we leave the van heater on a low setting the amount of Wattage used will depend on the temperature and I would need to experiment to get the correct level
    Perhaps only a Yorkshireman can understand the logic of this!
    The van is drained down I was thinking more about damp in furnishings
  8. CWH
    Jan 29, 2014
    2,971
    12,355
    Again, I may be mistaken, I know nuffin' about electrickery, but:
    But how much does that matter if its on EHU at home?
    I'm a Yorkshire Tyke as well so I understand the pennies-&-pounds bit, but surely it wouldn't cost any more than buying the extra heater in the first place?
  9. Malloney
    Malloney Read Only Funster
    Oct 12, 2014
    21
    9
    Kent
    We keep ours with all bedding in and ready to go,keeping background heat ensures nice smelling linen , I understand it's probably not totally neccasery but costs a miniature amount against the cost of mo Ho , also very handy when I get kicked out on a Saturday night, with TV and fridge of beer ime not complaining .I would suggest go max but def with thermostat ,I use a garden greenhouse heater 200w (element type ) £19.99 on eBay mounted on a piece of flat alluminium as the tubes are quite long at this wattage , I have a tube heater (small 60w) fitted in the garage just for peace of mind. Sorry I don't know how to do a link it's the only one I could see that comes up when you google 200 w greenhouse heater
  10. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,039
    6,051
    West Sussex
    Don't heat ours, never had any problems, heating only encourages condensation as warm air retains more moisture.
    • Like Like x 3
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,075
    2,920
    Kendal, Cumbria
    I use a greenhouse heater (500W) with a 'frost' setting. It switches at around 5 degreesC. I also leave a dehumidifier running on its medium setting. I drain down anyway.
  12. WillH
    WillH Funster
    Feb 9, 2008
    1,719
    1,427
    SW Scotland
    We used a tubular heater when we had a caravan, didn't really do the job. Since getting a motorhome we now use a thermostatic convector heater set on the 800w element. It's set to kick in at 8C. I have an electronic max/min thermometer in the van and last winter it only got down to 4C on a really cold night. I have no idea of how much it costs to run but as the van cost 3 times what my house cost I don't worry about the amount of electricity it uses. Can't be much as my bills are not excessive.
    • Like Like x 1
  13. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,343
    1,943
    South Staffs
  14. Mr B
    Mr B Funster
    Feb 1, 2015
    349
    954
    yorkshire
    Got ours on low setting using the Truma heater. Just plug it into the lamppost so it's always warm. Blinds are always shut so I can hide from SWMBO when F1 or Moto gp is on....;)
    • Like Like x 1
