Size matters.... (1 Viewer)
Devonian
Devon
Newbie
Hi everyone
I'm pretty new to motor homing and am in the process of purchasing my first MH.
I need to ask.... is a large (7.7m long) motorhome likely to present me with many problems when travelling around the UK?
Will it restrict where we can and cant go, or is this a fairly normal size vehicle for UK roads, town centres, country lanes etc?
How do others manage with MH's of this size??
Thanks on advance
Apr 28, 2013
3,682
80,851
Alentejo,Portugal
Hymer A Class
Since the '80,s
My last van was almost 7.5 metres long,the new one is 5.99.
I miss the space obviously but parking in car sized spaces is much easier sometimes.
I had no problems with driving the longer van in the UK,to be honest the long overhang beyond the rear axle on that van was the thing that needed paying the most attention to.
I drove HGV's for years so it wasn't a great issue anywhere except the tightest of turns but just thought something you may want to consider.
Sorry Devonian a big :welcome3: also,you will get all the help you need here.
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
Welcome from another (adopted) Devonian.
Lots of folk have big vans and have no problems with them, width is probably more of a factor. I think it really depends where you want to go. I've taken our 6.0m panel van onto Dartmoor and over some humpback bridges where some MHs would probably ground, especially those with long overhangs. We also like to explore off the beaten track roads in Europe and I wouldn't be given a big MH but as is often said, if the local bus can get there then so can a big MH.
If the MH you are thinking about has what you want internally then I am sure it will be fine.
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
scousebird
10,914
359,481
South East Kent
Bailey
March 2012
:pink:
we have a 7.5m MH and get around ok but Alan used to be HGV driver so not much phases him
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
:hiya2:
I are also new to the world of MH but mine is relatively small, only 6.7m.
Among the things that I learned years ago when driving horseboxes, a long wheelbase Ford then a Bedford TK, is that length only really matters when trying to turn left. Having to move over to the centre or even RH side of the road ensures that some p**** on a bike, motorbike or usually in a car sees this as an opportunity to overtake a big, slow-moving vehicle on the inside. To a lesser extent this may be true in a MH.
But IMHO width is more of an issue, overhanging trees being a fine example of that plus normal idiot driving behaviour from white van men on rural, narrowish roads. Height can be an issue , notably low streetlights overhanging the roads and trees again.
But I'm sure that you will cope and have many years of FUN with bursts of uncontrollable swearing of course.
Nov 6, 2013
3,201
229,474
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Hi and
:pink:
We changed from a 5.8m to a 7mtr van last year and have covered 10k miles without incident. It is a little more difficult to park in car parke but there is usually a spot where you can reverse in and overhang on the grass/concrete perimeter.
I'm sure you will enjoy your new motorhome.
Jul 29, 2013
9,071
18,520
Salisbury
Hymer B678DL A class
since 2011
:hiya2::welcomesign:We have a Hymer Exsis at 7.2 long but it is only 2.2 wide we have always had 7m plus vans but usually wider than the Exsis and it does make a difference but you'll soon get used to it.
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
:welcome3:
One thing different from car driving, apart from the width obviously, is the 'overhang' section behind the rear wheels. When you turn left, the overhang swings out to the right.
As you move off from a kerb with a lot of lock on the steering, to clear a parked car in front for example, the overhang swings left and can hit lamp posts, parking meters, trees etc on the pavement.
You soon get used to it, but it's something you don't think about in a car or even a white van.
Chris
21,053
278,728
None
10 years
We started with a 7.5 m van and then changed it for an 8m.
No real problems with either van. You just need to use your side mirrors more than in your car.
That's what I find anyway.
Lot lover
1,291
1,617
Lot, France
New boy
Particularly if you don't have a rear view mirror stuck to the windscreen and your rear facing camera shows a fine view of your bike rack and little else.
Aug 27, 2014
1,910
3,930
Shropshire
McLouis Tandy 640+
Since 2014
I've not found any great problems with my 7.5m van. A few roads I've not been able to go down - low bridges, weight limits, 6'6" width restriction (lot of those in the western Lake District I found) - but we've always got to where we wanted to go. I've always managed to get parked, sometimes a bit more of a walk is required than if I was in the car but that's it.
Biggest plus for me would be if the van was narrower - mine is 2.4m, some are as narrow as 2.1m - I'm not sure I'd actually get down many more roads but the ones I do go down now, but it would be more relaxing to drive and easier when I meet another large vehicle coming the other way. We do like very minor roads though!
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
Hi and Welcome! I would say it totally depends on what you want to do and where you want to go. Initially I had a 5.5m panel van conversion and apart from height barriers, would take it anywhere I would take a car. We now have a 6.5m coachbuilt and I have to be a bit more careful. On paper it doesn't seem that much longer but the main problem for me can be in car parks with small marked bays. I'll often check on Google Earth if it's somewhere we really want to do. If it's just a carpark, we'll ride round and if no good, move on to the next one.
ceejayt
3,208
5,816
Stamford Bridge - Yorkshire
RS Elysian A Class
Since 2004
We have a 9m van - parking in a town can sometimes be a problem but we park a little way outside and use our bikes if we have to. As someone said earlier, width is more of an issue - I always think "if a bus or a delivery van gets down this road then so can I" - even single track raids with passing places.
Take it at your own pace, don't feel bullied by those behind you and enjoy
Nov 30, 2009
6,547
148,985
Pickering
PVC the PUG
:hiya2:
Our PVC is 6.4m long and only 2m wide. We get to park in regular supermarket car parks , trying to park so we can over hang if pos , over grass etc. We've had no problems getting anywhere or parking anywhere. Even in the littlest villages and narrowest roads.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Look around and you will find lots of examples of people enjoying themselves in large vehicles, so it is perfectly possible. If you are of nervous disposition, though, go smaller rather than larger. It would be a shame to spoil a holiday due to concern about each journey and you are less likely to go out as often.
Having driven and towed large vehicles, I found that difficult situations didn’t crop up very often but, when they did, were readily accepted as a challenge and looked back on with satisfaction.
You will soon learn what suits best but that’s a bit late after the event. If you have no past experience (caravanning/boating) I’d recommend buying second-hand to start with as depreciation is much less. You’re unlikely to get everything right first time, unless you’re very lucky, to plan to keep your first one for only a season or two and treat it as a learning experience. It’s not the kit that matters. It’s what you do with it.
