Staiger SINUS BT20 Unisex, 52cm frame, 2014 model.
Bosch 250 watt brushless motor, crank mounted.
Bosch 400 watt lithium battery.
Bosch Active Line computer, controls power settings. shows trip distance, trip time, range, time, max speed, average speed, odometer. Has automatic back lighting for night time use.
Max speed with motor assist 25kmh (16mph) The motor cuts out at 25kmh, but the bike will then go faster under pedals alone. This arrangement makes the bike legal without licence in EU countries.
The computer gives five power settings in which the bike can be ridden. Off, Eco, Tour, Sport and Turbo. Eco setting is adequate for most cycling, even steep hills, and will give a typical range of 90 to 100 miles. By using a combination of off on slightly downhill sections and eco we usually get ranges of 120 miles on a charge.
Gears are Sram Dual Drive, 24 gears with index trigger changes.
Magura hydraulic brakes.
Suntour telescopic forks.
Seat post suspension damper.
Schwalbe 50 Energizer Plus puncture resistant tyres. Good condition. ( Spare tyre and tube included)
Datatag registered. Can be transfered.
Pannier carrier. Bag also included.
Front dyno hub with front/rear lights. Lights stay on for several minutes after stopping.
Mud guards.
Trelock through wheel frame lock.
Mains charger.
Bell.
Frame mounted stand.
Kryptonite D Lock included. Cat 10 gold rating.
Professionally serviced 2015.
Continually maintained by bike enthusiast owner.
New cost Jan 2014 £2000. This is a high end, quality German bike.
Item located in Suffolk.
Could deliver up to 100 miles.
To view images, right click on icon at top of message and select "view image"
If link to pics does not work message me and I could e mail.
£750 ono
Robin and Lisa
