Sink drainage, how quick? (1 Viewer)
Douzeper
Nov 23, 2010
234
57
Antrim, Northern Ireland
Newbie
Took our MH out for the first time (was great!), noticed the sinks in the kitchen and bathroom seem very slow to drain, is this the norm? does the pipe perhaps need cleaned? what would be best to clean it with?
Thanks!
GJH
29,450
38,828
None, now sold
2006 to 2022
Some vans do suffer from slow drainage. Our shower and washbasin are OK but the sink is a bit slow. The normal reason is pipes being bent round appliances (the fridge is below the sink in our van).
To make sure the pipes are clean (and to stop niffs) we use Link Removed as part of the cleaning of the van after we get home from each trip. It can be a bit pricey in some shops but both Aldi & Lidl have it as a Special from time to time.
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
air lock:thumb:eek:pen the drain valve's and then try them:thumb:
Jan 11, 2010
2,743
9,476
Chester
Auto-trail
Well that`s our 13th year & still loving it.
Thanks!
How old is your MH. the newer MH`s have a watertrap in the outlet that really does restrict the flow of the draining water.
We altered the pipework taking out the trap, not a problem as we don`t empty into established draining systems so no worries of any nasty smells coming back up the pipe.
beachcaster
3,044
3,161
east sussex
a few years
SWMBO was complaining that the sink was taking ages to drain...she is not very technical so I had a look......I explained they did drain quicker if you took the plug out :)
Its now just a case of waiting for the revenge :Smile:
barry
poppys
165
40
Norfolk
Since 1974 on and off
I found mine was like this and that the pipe from the waste on the sink was badly routed.My sink is above the fridge with very limited space ,the pipe actually went up when it left the sink.Under the van there was an excess of pipework again badly routed,once this was sorted things did improve.The other thing that has a baring is the leveling of the van ,Ive found that just slightly raised at the front makes an improvement.
wasp
1,724
18,180
Warsop
None gone caravannin
Don`t forget these wastes are not your normal 40 mm pipe same as the sink at home they are at best 25mm and corrugated plastic.you do get a bit of a build up I got a plunger on mine and did it gently:thumb::thumb::thumb:
MHVirgins
3,889
3,158
South of Scotland
March 2011
Sink drainage, bit slow!
We have a similar problem with the sink and shower draining away. I would say the sink is much slower to drain than the shower, but as "wasp" says the pipes are a lot narrower and will take a little longer to drain. We bought a plunger thinking it might be a bit of a build-up of food particles etc, which brings us back to the need for levelling ramps on some sites.
I find the slow draining of the sink very annoying because it's always me that washes the dishes:Angry: while hubby has a shower!
old-mo
Extra Special
16,341
93,473
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
I find the slow draining of the sink very annoying because it's always me that washes the dishes while hubby has a shower!
Get Hubby to take dishes into shower with him...
Kill to birds with one stone ,so as to speak, and save water.. :thumb:
FULLMOON
182
153
devon
FORD/BONGO CONVERSION
i'm a newbie
We had the same problem the sink drains very slow and nasty smells came from it , I whent to sort the problem and found the wife had used it for no 2s :Eeek: :ROFLMAO::ROFLMAO:
Squire
324
60
Too much information ....... :whatthe:
