Silver Screen
Discussion in 'Motorhome Chat' started by wessex wanderer, Nov 4, 2012.
  1. wessex wanderer
    wessex wanderer Read Only Funster
    Sep 8, 2012
    12
    Hi Guys, Have a problem with my silver screen or it could be the door seal, the passanger side door leaks when i fit the sreen. Bought the screen 2011, the motorhome is 2012 Bessacar E564. I tried a seach of the site and found nothing... any ideas what the cause could be??
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi are you trapping the thick part of screen in door instead of just the flap ?
    You could also bend the top of the door slightly to make a better seal :thumb::Eeek::Eeek:Drop glass down, open door,stick knee into door and pull towards knee gently :BigGrin: NO DOUBT I SHALL GET ALL SORTS OF COMMENTS but on older trannys it was the only way to adjust the top bit of the door :BigGrin::thumb::Eeek:
    terry
  3. robnchris
    robnchris Funster
    Jan 11, 2010
    1,384
    1,807
    Chester
    My mate had the same problem, the water would run in above it and because of the poor fit ran inside the door, he cut the flap that goes inside the door and that has cured the problem.
  4. wessex wanderer
    Sep 8, 2012
    12
    I'm sure that I am fitting the screen correctly, also sure that when the screens not on the door dose not leak though i am now keeping a close eye on it.
    I;m sure your going to get a few comments on the bendy door fix:Rofl1:
  5. wessex wanderer
    Sep 8, 2012
    12
    Sorry if i'm being a bit thick here but if you cut off the flap how will it stay wrapped to the door
  6. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    i suppose its down to water tracking down the inside of the cover.
    there is a way around this but it is up to you how to cure it.
    this is what i would use fitted above the door to reduce the amount of water that can actually get onto the top edge of the cover. http://www.johnscross.co.uk/products/fiamma-drip-stop-3m.html
  7. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Knee on the door frame and pull in top section is a standard mechanic/dealer way of dealing with this problem. Or at least it was with Morris Marina's in the 70's - Wadham Stringer, Guildford
    On one particular model once, you could see an inch of daylight at the top of the door frame if you sat in the passenger seat.
    And we wonder why we no longer have an indigenous motor industry.....
    :Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
  8. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Same problem here-but only a small amount of water coming in.I put a chamois leather on door arm rest and that soaks it up satisfactorily :BigGrin:
    Mike.
  9. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i assume door does not leak when the silver screen is not fitted?
    i would see if you can adjust the door catch to put pressure on the door seal or even consider changing the door seal... before i thought of " bending the door" :Eeek: and maybe making it leak elsewhere or cracking the paint.:thumb:
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    In my defence I did say bend gently :BigGrin::Wink:
    I think he is trapping the screen in the top of the door-- when I fit ours I make sure that only the flap bit is touching the door top (pull it down) because if the thick screen bit is touching the door top/gutter then it can cause it to leak
    terry
  11. Phill D
    Dec 6, 2011
    4,414
    4,633
    South Wales
    :thumb:
  12. wessex wanderer
    Sep 8, 2012
    12
    I think I've got this sorted, the water is tracking the screen (the screen is fitted correctly nothing trapped in the door) then running down inside the door. I did the same as Mike though I used a towel. Thanks to you all for your suggestions and help
    Ian
