Silly Question 1 - Controller To Battery Cable Run
Discussion in 'Solar Power' started by EssexBoy, May 26, 2015.
  1. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    331
    230
    South Essex
    Hi All
    I'm planning my solar panel installation, and am thinking of using the hole in the roof left behind after I remove the broken satellite dish to run the cables into the van. My issue is that the cables will enter van quite some way from the batteries (5+ metres?), so do I have a long run from panel to controller or from controller to batteries? Or do I just forget re-using the roof hole, and make another more hole in the right place to keep the run as short as possible?
    For completeness, my control panel doesnt support a solar feed, so its not involved in any cabling...
    Thanks in advance
    Steve
  2. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    331
    230
    South Essex
    Any thoughts anyone, please ????
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    Controller nearest the batteries
    • Like Like x 1
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    keeping the controller near the battery will give you the more precise reading otherwise as long as both sets of cables are the same thickness it makes no differance
    • Like Like x 1
  5. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    331
    230
    South Essex
  6. Techno
    Jul 28, 2010
    14,140
    15,091
    Any volt drop is better on the panel side of the regulator as the voltage is higher but use 6mm2 if you can but certainly 4mm minimum.
    You can buy lengths with MC4 connectors pre fitted on ebay
    • Like Like x 1
