Sikaflex sealants and adhesives
Discussion in 'Tech/Mech General' started by kex66, May 29, 2012.
  1. kex66
    kex66 Read Only Funster
    Jan 29, 2012
    166
    202
    cheshire
    Posted this on RVOC, thought it might be useful to Funsters as well:
    OK, as promised I am back from my site training at Sika UK and have a vast amount of information regarding sealants and adhesives for the Caravan/ Motorhome and Train carriage building market.
    Unfortunately, as I am as thick as pea soup and the technician helping me with my enquiry was a boffin in the extreme, I tended to nod my head in agreement far too often when I should have said "Was that actually English you've just spoken"[​IMG]
    However, I did remember some of it and wrote most of it down. The technician was also kind enough to give me his direct line number if I have any questions in the future.
    If you already understand sealants and adhesives then stop reading now. This is realy for those, like me who know nothing:
    Sika adhesives are designed to be used with no other fixation device needed. Correct preparation of the substrate is therefore vital. The correct procedure and products needed for caravan/ RV work:
    Pre treatment - Activator 205
    Primers - Steel/ Aluminium - Primer 210
    Plastic - Primer 206 G + P
    Painted Substrates - Primer 209N
    Interior Sealant - Sikaflex 221
    Exterior Sealant - Sikaflex 521UV
    Structural Adhesive - Sikaflex 252
    The pre-treatment and primer phase are vital.
    Unfortunately, only loctite manufacture products compatible with rubber coated substrates (Roof coatings etc)
    I hope this helps. If you need any further help then PM me and I will contact the Sika technician[​IMG]
    • Like it Like it x 1
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    so if i understand what you wrote for sticking a sat dome to the painted aluminium roof of a motorhome you first need the activator 205, primer 209N then 252 oh and plastic primer 206 g+p for the bottom of the dome.
  3. kex66
    Jan 29, 2012
    166
    202
    cheshire
    Correct.
    However, although I saw many examples where these products were used without additional fixation (Bolts etc), including spoilers on GT racing cars that reach speeds of 160+ MPH, I will also be bolting my sat dome down when I fix it. Only because I have no experience with this technology and wouldn't be confident with something as heavy as a sat dome.
  4. Gazzet
    Gazzet Banned
    May 29, 2012
    5
    London
    use sika i coll or simple polyurathene its super tough and lasts.In fact even butal rubber would hold your sat dome down in a 140mph gale
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi IF you look on Sikaflex web site it tells you all this and which to use for what :Wink:
    terry
  6. Organplayer
    Organplayer Funster
    Dec 11, 2011
    94
    30
    Berkshire
    Sealants
    For what it may be woth,info wise, there is a very good adhesive sealant on the market which can be purchased from Jewsons builders merchants and no doubt other outlets. It is called "Sticks Like S..t" And it does.
  7. kex66
    Jan 29, 2012
    166
    202
    cheshire
    I looked before going on site. Probably one of the most confusing product ranges on the market. I thought a quick chat with the technical dept to narrow the choices down may help those like me with no knowledge of sealants and adhesives:Wink::Wink:
