Lenny HB
- Oct 18, 2007
- 53,404
- 149,850
- Hymer B678 DL
May have been posted before.
Just found out that Silicon Sealant Remover dissolves Sikafex a treat.
Everyone says how hard it is to remove. I was removing a solar bracket did the usual sawing with a cheese/clay wire for 20min, then scraping the residue off with a blunt chisel. Then I thought I would try the Silicon Sealant Remover, it worked better than it does on silicon absolutely brilliant.
The next bracket I put some remover around the edge and while sawing kept coating the wire with the remover, got through it in a fraction of the time and a lot less hard work.
