Sikaflex removal (1 Viewer)
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
I've just got my new satellite system and need to remove the old Sikaflex from the roof of the van.
Any ideas of the best way to do this?
TheBig1
17,630
43,262
single edged razor blade or glass scraper is the best way i have found. its not designed to peel off easily
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi I have a sharpened 3 ins scraper and a piece of wire with handle s on to cut loose what ever if you cannot get the scraper to do it ---a bit like a cheese wire
terry
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You can buy silicone remover from places like screfix and B&Q. Not sure how well it works on Sika because never had to use it
Sikaflex is not made from silicone, in fact it is specified as silicone-free, so a silicone remover wll not touch it. Both Sika 221 and 512(Caravan) are made from polyurethane. According to the product data sheets, once cured, the only way to remove it is 'mechanical' - i.e. cut it off.
Silver Tourist
4
10
Chester
C class Autotrail Apache
Since 2012
Firstly it will probably make more of a mess than it already is , if you remove it mechanically it will more than likely chip the paint off the roof panel.
Secondly , I suggest you leave it alone , after all no one except you will ever see it on the roof and if you sell it you would be very unlucky to find a buyer that makes an issue of it.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
As previous I use a very sharp old wood chisel ...delicately .residues can be cleaned with cloth white spirit and small amount of acetone ,re-sica with new unit clean new residue excess with white spirit jobs a good-un and of course a bit of elbow grease(y)
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The point about a very sharp wood chisel as opposed to a craft knife is that if used ground face down you get very good control over how far above the surface you are cutting (a bit like woodwork really :whistle2:). It takes a few attempts to get close to the roof surface but it's easy & doesn't do damage.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Rapido has a anti hail coat that is not flat unfortunately it's like a herring bone pattern for want of a better description. Personally I would get it as flat as possible and put a large square plate over the whole area that will make a better foundation for the new sat.
Techno
Jul 28, 2010
15,475
20,756
May 2010
It's not painted on this van but GRP anti hail skin
Jan 19, 2013
132
109
Worcestershire
since 2010
I agree with the sharp wood chisel method ….. have had lots of experience removing sikaflex from boats and less so from motorhomes. For the final removal of the residual excess etc …. I have always used cellulose thinners. (this may also remove any colour from the substrate material however) but on the roof unlikely to be a problem.
Kevan
1,097
968
Kent and south west France
van conversion
30 years caravan/motorhome
Ditto: the wood chisel wider the better; removed my solar panels with cheese cutter wire (easy to buy car windscreen fitters use it to remove old screen) then bought cheap chisel from BQ
removed all residue without scratching paint, final clean with lighter fuel and clean cloth.
f6c
Nov 7, 2010
10,960
4,790
gloucestershire
Carthago Malibu 640
23 Years
Do you have to remove it? What about a paint over?
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
Watched a Spanish dealer take some off last month. He was using a especially sharpened 3inch wide paint scraper that he periodically honed. Driving it gently, flexed flat, with a mallet he made short work of it and left almost the original surface. It was so sharp that you could have shaved with it.
Dick
Techno
Jul 28, 2010
15,475
20,756
May 2010
Good Alan but be aware it is only for removing "uncured" adhesive
Jul 12, 2013
3,872
5,272
The City of Henlow
Adria Supreme
Since 1980
I noticed that but people continued referring to the same product as part of a cleaning process, perhaps it takes a long time to cure right through.
Alan
