Sikaflex 521 against 552 (1 Viewer)
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
Go back to sleep Mel
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
I'm looking at fitting a solar panel Andy.
I know what it does but want to know the difference
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Use 512 like most others do :xThumb:
Broken Link Removed
EDIT There's at least 40 panels being driven around that I'm responsible for. No one has one on the road behind yet :xlaugh:
Sika 512 is National Caravan Council Approved, and as one of the worlds biggest and trusted manufacturers Sikaflex 512 Caravan will work!
Minxy
32,641
66,519
E Yorks
Carthago Compactline
Sikaflex 552 White Elastic Adhesive Fixing 300ml For Caravan Motor Home Boat Solar Panel Mounting
  • UV, ageing and weathering resistant
  • Bonds well to a wide variety of substrates with practically no need for priming.
  • Capable of withstanding high dynamic stresses
  • Can be overpainted, Low odour, Non-corrosive
  • VOC and solvent free, Silicone and PVC free
Designed to bond well to a range of surfaces such as ceramic materials, plastic and aluminium, Sikaflex 552 is UV and weather resistant and is capable of withstanding high dynamic stresses.
Sikaflex 521 300ml Multipurpose White Adhesive Sealant For Caravan Motor Home Boat Solar Panel Mounting Wood Metal Fixing
Designed to bond well to a wide variety of surfaces such as wood and metal this high quality adhesive is UV and weather resistant and can be sanded and over-painted.
Minxy
32,641
66,519
E Yorks
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
The real difference is the workable temperature that you can work with them, which is an important feature when fixing in the winter months ! frommemory but I could be wrong the lower temp one is 512. Do check it ! ;)
PS when you come across a cheap offer, check its' best by date, it DOES go out of date cheappie offers are often past sell by date, stock clearance ! so beware !!
Techno
Jul 28, 2010
15,475
20,756
May 2010
requires a minimum of 5C (throughout the setting period)
Moodybrook
802
651
still in nappies
Yup Andy, think the others are higher temp requirements?? It was important to me as we can sometimes achieve 5 degs in Scotland in winter, but not much higher !! and I didn't want to wait till July !! (y)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
No real danger though - if it's out of date it's usually impossible to get it out of the tube :).
Minxy
32,641
66,519
E Yorks
Actually of the 4 tubes I bought at the car boot sale, 2 were in date until August 2015 and 2 until May 2015, as it was August when I did the solar panel I thought I'd try the 'out of date' May ones first and it came out of the tube no problem ... gotta find something to stick with the other 3 now to get my money's worth out of them! :xgrin:
Moodybrook
802
651
still in nappies
no problem
Was just a heads up comment as the first one I got off ebay wouldn't come out. Well not very easy so reordered fresh ones from a chandler.
Actually in the end as my experience had dented my confidence, the Black and Decker came out and I BOLTED the sod down as well. Yes through the ROOF !!! but she ain't going nowhere without the rest of the WHOLE roof !! maybe that should be the holed roof ? :whistle2:
Minxy
32,641
66,519
E Yorks
Believe me you KNOW it's still usable when it sticks to everything in sight ... trust me I know!!! I had it on my hands, jeans etc for weeks afterwards!! :xgrin:
