Sikaflex 252
Discussion in 'Solar Power' started by wp1234, Jan 14, 2010.
  1. wp1234
    wp1234
    Oct 23, 2009
    116
    Anglesey North Wales
    Im told that Sikaflex 252 is the best stuff to use to attach solar panel brackets to the roof without resorting to drill ffixings. But at £20 a tube I am begining to wonder if this is the case ? Anyone used anything else eg Sikaflex 512 (£9) which seems according to the blurb to tick all the boxes.
    CHEERS IN ADVANCE
  2. Macytia
    Macytia Read Only Funster
    Nov 30, 2009
    66
    North Wales
    I used 221 on my van conversion, used it to glue timber battens to the metalwork, they are solid and holding a decent weight to date.
    I bought 12 tubes via ebay for £30 delivered, you could use what you need and resell?
  3. C.L.S
    C.L.S Trader - Service & Repairs
    Jul 22, 2007
    410
    49
    I also use Sikaflex 221 less than £7.00 a tube :Smile: Never lost a solar panel or satellite dish off the roof :Rofl1:
    Mark
  4. Benni-Boy
    Benni-Boy Read Only Funster
    Feb 10, 2009
    47
    Halifax
    I use Sikaflex 521 from E-Bay supposed to be what the caravan manufacturers and repairers use. Great stuff. Never had a problem. Used it to re-bed the roof rails.:Smile:
  5. nickit
    nickit Read Only Funster
    Jan 6, 2010
    7
    Nottingham
  6. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    No Probs Nick.
    I've always found O'leary's very good at supplying what I order.
    Steve.
  7. Johnnie Gee
    Johnnie Gee Read Only Funster
    May 1, 2009
    59
    19
    Near Aberdeen
    Sikaflex
    Hi,
    We use it offshore for repairing small boats and the like, seems to be the best you can get:Smile::Smile:
    JJ
  8. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,671
    Ecclefechan
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,755
    6,252
    South yorks
    Hi I USED 72 TUBES of POLYSEAL 101 & 102 in the construction of my self build
    http://www.hodgsonsealants.com/ --- now I think it has changed to Polyseal 40
    excellent stuff and every bit as good as sikaflex :thumb: I bought it from O'learys at £2 a tube.IF you manage to get some at a good price give me a PM as I would have no problem buying another 5 / 6 boxes and saving it for my next project.Nothing I have stuck with it has moved or leaked :thumb:
    terry
  10. tinyusrv
    tinyusrv Read Only Funster
    Jan 15, 2010
    Hi,
    First post..... wondering how you reseal the tube if you don't use all of it.
    Great forum !
  11. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,980
    9,171
    Wrenthorpe, Wakefield.
    Hi tinyusrv,
    welcome to the site, its very addictive. You'd be better going on the "introduce yourself" bit for a propper welcome though :BigGrin: you've been missed on this !
    We used sikaflex 221 to fix the solar panel to the caravan roof. Brilliant stuff . You must make sure you use the primer (210T £3.22 ) before bonding though.
    We managed to prize the panel off when we pxd the caravan for our MH in December. Took ages to get it off with a stanley blade.
    We are waiting for the weather to warm up , before fixing it on the MH as sikaflex has a working temp of 10 deg.
    It also has a 9 month shelf life, so unless your planning on using it all within that time, once opened , theres no point re- sealing it.
    Ralph usually sticks a nail or screw in the end of his silicone tubes, so you could do that , with the Sikaflex i guess.
    We get ours from www.aireandsun.co.uk
    Infact we got the Kyocera solar panel , regulator and mounting kit from him as well.
    Highly recommended:thumb:
    Bev
  12. Terry
    Terry Funster
    Dec 27, 2007
    10,755
    6,252
    South yorks
    Hi, once opened Sikaflex will cure overnight :cry:so make sure you get everything stuck/ sealed or it will be wasted.If you leave the nossel on then put on a new one you may get another day out of it
    terry
  13. finby
    finby Read Only Funster
    Oct 3, 2007
    236
    norfolk
    Used Sikaflex to glue on a spoiler to the roof (to direct wind over the overcab bed rooflight) - Its been on for three years now without any problems at all!! Would highly recommend it.
  14. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Welcome to the Fun Site.
    Sikaflex is great stuff.As Terry says...Make sure everything's sorted before opening it though.:thumb:
  15. Dipstick
    Dipstick Read Only Funster
    Sep 11, 2009
    6
    Devon
    We used Sikaflex 221 to fix an 85 watt solar panel without any screws on our PVC. Used 4 aluminium plates each a footprint of 200x75mm.
    Each plate drilled 10mm in two places to allow a mechanical location to form. Degrease with meths or petrol and abrade both surfaces with 200 grit abrasive sheet and warm with a hairdryer to ensure no moisture.
    One 300ml tube is sufficient and will give a thickness of 3-4mm. Allow 24 hours per 1mm thickness of adhesive for curing before driving. No need for fancy primers or curing agents doing it this method.
    Bought our tube of Sika from ebay £3 with a short shelf life remaining.
    Worked well for us, good luck.
    Pete
  16. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Sikaflex 221 is certainly a strong adhesive, but there are more things to be considered that just attaching the solar panel.
    If you mount the panel on hinges so that it can be tilted up to the sun you can increase the output of the panel by approx 1/3.
    If you have a aluminum skin on the roof of your MH you don't won't the panel bouncing up and down pulling the aluminium with it.
    Should you go for the "stick down method" it can be difficult to remove if you change you mind at a later date with the position of the panel.
    I have found that by far the best solution, all be it more expensive is to fit a roof rack to the MH then fit the panel/s to the roof rack.
    Doug...
Similar Threads
  1. RidersofRohan
    28
    1,261
