Sigma S30 alarm - Help!
Discussion in 'Motorhome Chat' started by umper lumper, May 29, 2009.
  1. umper lumper
    umper lumper Read Only Funster
    Apr 15, 2009
    6
    County Durham
    Hi,
    I own a CI motorhome with a Sigma S30 alarm. Unfortunately I have no instructions. The alarm activates and de-activates ok, but is there a way of de-activating the internal sensors to allow the exteria to be alarmed whilst occupied?
    Hope that you can help.
    Best Regards
  2. beemerboy
    beemerboy Read Only Funster
    May 22, 2009
    8
    wemyss bay(where?)
    sigma alarm
    Hi ,I also have a sigma alarm fitted and have the same problem although I do have the instruction booklet, according to which, the vehicle is fitted with a touch pad to the inside of the windscreen ? you have ? anyway when the vehicle is new the original owner would be provided with 2 sticky labels with a PIN number (dont ask why they are sticky) and a cetificate of installation I tried to get this number from the previous owner who is the original owners nephew because you cannot set the alarm system to exclude the PIR s unless you have the number.The number would also be used in the event of being unable to disarm the security system becuase the battery is flat in the fob meaning without which you aint going anywhere! .My previous owner said he did not have the number and neither did his uncle ????? the only way around it is
    1) make sure the battery never goes flat
    2) have the system removed and re install another (£450) if memory serves the main agent is about the Birmingham area
    if you want a copy of the manual I could probably oblige
  3. williamb
    williamb Read Only Funster
    Apr 28, 2008
    42
    14
    Lancashire
    i presume you have the remote with two buttons if so to disarm the ultra sonics press the smallest button twice after arming the system this will isolate the ultra sonics.:cry: for the next person about keypad when getting out of the van turn on the ignition on the keypad type 2 then immediately turn off ignition leave van then arm alarm this should delete the sensors but i will only do it untill the alarm is next armed.
  4. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    There should be a serial number on the alarm control, just about where you set the pin number. If you get that you can contact sigma, their email and telephone number is on their website.
    Ask them for the original security code, if its been cahnged from the original they may not be able to help you. As long as you can demonstare proof of ownership they should be able to do something for you. They have been very helpfull to me when I cantacted them.
    All the Best, Jim
    :Smile:
  5. umper lumper
    Apr 15, 2009
    6
    County Durham
    :thumb:Thanks for everyone's responses, very helpful. Will try these this week-end!
Similar Threads
  1. PeteH
    22
    492
  2. Chrisy
    70
    1,339
  3. FrankCoffi
    305
  4. David wright
    253
  5. ojibway
    6
    647
