side repeaters and emissions
Discussion in 'Motorhome Chat' started by electricscott, Sep 30, 2014.
  1. electricscott
    electricscott Read Only Funster
    Nov 23, 2010
    198
    72
    Buckden Marina
    gulfstream montage does not need an MOT until next april but we are travelling abroad and wont be back until May next year, so decided to get one early. Failed on emissions (even on LPG) and no side indicator repeaters. not sure how it passed the initial registration!
    went to the MOT station on LPG and was asked to switch to petrol, should I have driven there on petrol? leaving UK on Friday so not much time to sort out these issues.
    any advice is appreciated
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    It should have been tested on whatever fuel it was presented on.
    Sounds like the tester didnt know how to reset his machine.
    I have been asked 3 times what fuel i run on as the system defaults it to diesel even though its corrected each year, then its tested on LPG or petrol depending if the system has cooled too much for LPG.
    Passes every time but i have yet to see the exhaust probe being inserted....same as the park brake test, does it work ?....yes.......its passed then.
  3. electricscott
    Nov 23, 2010
    198
    72
    Buckden Marina
    thanks pappa john, he did seem out of sorts, it might be worth getting the emissions tested somewhere else, what do you think of the repeaters?
  4. pappajohn
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    There are regulations on repeaters depending, i believe, on wheelbase and overall length
    Over a certain distance repeater are required and every so far along that distance but i dont know what the dimensions are.
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,916
    17,607
    notloB
    Personally I would go somewhere else on petrol and point out that it was registered without repeaters. If the law has changed so be it but they can't make you retro fit them.
  6. pappajohn
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    Sorry, my confusion......i thought you meant side marker lights.
    Repeater indicators are required if the front lens cannot be seen clearly from the side....and slightly rearwards i think from memory.
    So, if you have wrap-around front flashers it should have passed.
    If you have forward facing flashers you need a couple of small rectangular surface mounted indicator lights wired into the front flasher lights or on to the spare pin on a 5 pin flasher unit.
    Doing that they will light as the main ones go off but that doesnt matter.
  7. pappajohn
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    Vehicles first used on or after 1 April 1986 must be fitted with one side repeater indicator on each side. Instead of a separate lamp, the side repeater might be part of the front direction indicator if it includes a wraparound lens.
    http://www.motuk.co.uk/manual_140.htm
  8. electricscott
    Nov 23, 2010
    198
    72
    Buckden Marina
    I am in Southsea Portsmouth and Internet is poor only just managed to get back here to thank you for your input
    Looks like I will be fitting repeaters
