Side Marker LEDs wiring
Discussion in 'Tech/Mech General' started by spindrifter, Nov 13, 2009.
  1. spindrifter
    spindrifter Read Only Funster
    Apr 27, 2009
    43
    Hi All
    I am thinking about fitting LED side marker lights - but need help with the following:
    Can I take the supply from the tail lights?
    Would I wire them in parallel or series?
    What would be the best way to make the joints waterproof?
    Thanks in anticipation
    David ..... Spindrifter
  2. hilldweller
    Dec 5, 2008
    27,771
    26,861
    Macclesfield
    Possibly.
    Parallel.
    I often solder and coat joints in contact adhesive. More than one layer. Otherwise self amalgamating tape.
    It's "possibly" because modern all singing and dancing electronically switched lighting ( CANBUS ) might measure the current, see it is above nominal and turn off the feed. But if it's good old SWITCH no problem with any normal LED load.
  3. spindrifter
    Apr 27, 2009
    43
    Thanks for info, really helpful but, - what is "self amalgomating" tape?
  4. hilldweller
    Dec 5, 2008
    27,771
    26,861
    Macclesfield
    It's a black rubber tape, soft and stretchy, not sticky. The clever thing is, it's treated with something that after it's stretched round a joint it bonds together in a water tight seal. All good aerial installers use it.
    Self-Amalgamating Tape : Self Amalgamating Tape : Maplin
    Not cheap but very good.
  5. wiljoy
    wiljoy Funster
    May 23, 2008
    919
    999
    Crook, Durham
    Hi David, I've just fitted 6 marker lights to my vehicle. As it is the new generation vehicle with CANBUS electrics I took the feed directly to the fuse box and have had no problems.
    Good Luck,
    Wilf
  6. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
