Shurflo Pump Spares (1 Viewer)
Jul 24, 2009
4,327
104,191
South Yorkshire
Since 1999
I knew I was tempting fate by saying we hadn't had any problems with our motorhome. Just got back from Hawes where the ShurFlo pump has developed a leak between the pump halves. I believe that complete heads are available but does anyone have a recommendation for a supplier please?
TheBig1
17,611
43,138
sometimes you can just tighten the screws. the service kit is pretty expensive
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
From experience, its probably cheaper to replace the entire pump in the long run. ;)
I agree, after several attempts to repair diaphragm pumps I have come to the conclusion that its not worth the effort, if it leaks or doesn't move enough water or won't shut off just replace it.
D.
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Did mine 2 years ago.new diaphragm .old one didn't have a gasket between joints.new kit came with gasket.not had any problems.Cost 18 pound's.got mine from leisure shop.com (y)
funflair
19,318
30,120
Guisborough
MORELO palace
since 2012
When ours had a little leak it was just because calcium deposits had formed in the joint and allowed a small leak path.
Strip the head down gave everything a good scrub and rebuild, I put a bit of Vaseline around the diaphragm/head joint and job was a good un and still is, that's the second one I have done as we had the same in the caravan.
Martin
scotjimland
2,288
9,905
A Woosh bang
Before buying anything.. As big1 said...
I'd remove the pump housing, clean it out and provided there is no visible cracking or damage to the diaphram, reassemble adding a smear of Vasaline to the diaphragm sealing edge... it's important to tighten the screws equally and not too tight..
EDIT
just saw @funflair post.. great minds
buckby
213
147
nottinghamshire
coachbuilt
Change ours from 20psi to 30psi because the old one lost performance as the toilet was not flushing all the way around the rim now with the 30psi loads better
canopus
6,136
10,251
rural Lincolnshire
Carado CV640 Pro
Since 2010
You have to be careful increasing the PSI rating of a water pump. The PSI rating is often matched to the specific boiler/water heater fitted to the vehicle i.e. in our van, 20 PSI for the Alde 3000 boiler.
canopus
6,136
10,251
rural Lincolnshire
Carado CV640 Pro
Since 2010
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Yes and the push fit plumbing is a risk, you can bet it will fail in the most arshole of a place to get to!! Worthwhile checking the spec from the boiler as Canopus has identified.
TheTwoOfUs
Jul 24, 2009
4,327
104,191
South Yorkshire
Since 1999
I concur with all the warnings about increasing the pressure of a system. My working life was spent designing hydraulic systems so I know the problems involved when increasing the pressure without due regard to the designed working pressure, even at these very low pressures.
