Shower waste (2 Viewers)
Royston Gallagher
Chausson suite garage
9 years
Hi, I have a Chausson suite garage and my shower plug hole (waste) has broken and dropped underneath the shower tray. How do I get to this and renew the waste ?
JockandRita
11,462
150,156
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi Royston,
Not a Chausson, but on our Hymer, access is by a plate screwed to the locker ceiling, underneath the shower tray. If you have a double floor, then there is a good chance you may have similar access. If not, then like John advised, the shower tray will/may need to be removed. :(
Good luck with that one. (y)
Cheers,
Jock.
R
Royston Gallagher
9 years
I looked at taking the walls apart but each time i took one thing off there was another and another so i stopped.
I will get some mats out tomorrow and look underneath to see if there is any access that way ?
If not i might have to cut an access panel underneath. The new part is only 89 p
Mar 23, 2012
9,545
32,090
sleights
c class
On our old flash 03 there was an access panel in the back under the lower bunk. There were 2 plastic grills which could be removed to look under the shower tray you might have similar? Try looking at a low level in your garage if the shower is next to it
David
