Shower Tray Benimar (1 Viewer)
village
11
EAST ANGLIA
COACHBUILD
hi ,small amount of hairline cracks are appearing in shower tray that appear not to be sufficiently supported underneath . common problem .i am thinking of drilling a small hole into the outside wooden surround and using expansion foam to provide a hard base is there any thing under the shower tray appart from plumbing that i should be concerned about thanks in advance ,
Vouty
30
20
West midlands
hymer s630
New
Have just done something similar with my Hymer although it was to stop a small leak in the shower drain 90 deg bend. Should be fine provided you never need to get under there - there were pipes and heating ducts under mine so just be aware that the heating ducts will get quite warm.
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
You need to be careful that the foam does not blow too much and lift the tray base and then set.
If you can get it out I would be inclined to reinforce the back with epoxy and glass fibre.
Martin
TheBig1
17,630
43,252
the easiest and cheapest route would be to get the tray sprayed with bed liner rubberised paint rather than replace the cracked tray
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
how much would it cost to have shower tray re coted
TheBig1
17,630
43,252
what colour dose it come in inly black ?
bill
Hi Bill it comes in nearly any colour. you can buy cans in a car accessory shop
getting it done professionally costs from about £150 upwards depending who you use. its the same stuff used to coat the inside of refrigerated vans so you dont need to go to a motorhome/caravan specialist
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
I will have a look tomorrow not paying £150 will re spray it my shelf thanks for the info @TheBig1
Minxy
32,646
66,526
E Yorks
Carthago Compactline
I'm all for DIY but if you don't reinforce the tray, just spraying it with a coating won't stop it 'sagging' ...
V
village
11
EAST ANGLIA
COACHBUILD
thank you for the advice will use foam targeting the unsupported area then use rubberised paint that i bought of ebay .very difficult to remove tray thancks again
