Shower time limit ? (1 Viewer)
May 31, 2015
11,631
44,300
Cornwall
Ducato PVC
Getting Better
we have a Truma C6002EH and while I find it ok to have a shower as I turn it off between soaping and rinsing but Mrs bu'ckett finds it goes cold on her, now she does not turn off but it does seem to go cold quickly.... I have it on the hottest setting before hand and it is very hot so it is working ok....
So what's the awnser..? A smaller shower head..?
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
When I use showers on campsites it amazes me just how long people can spend in a shower. You only need to get wet, soap up, and then rinse. Mind you I don't have any hair to worry about.
Carol
14,049
112,001
North Wales.
Think the answer is to do the same as you, much as I would like to just let it run it doesn't work that way. Sometimes I rinse my hair off over the sink to get the Last of the soap, with Motorhome sometimes you have to make slight adjustments.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Your boiler probably has about 10 litres of water in it ( about 2 gallons). When you turn the tap on, cold water flows into the boiler and has to be heated up. If you have it on the hottest setting, you will run out of hot water quickly. We found it was best to stagger our showers or at least wait till the water was up to temperature again before the second person gets in.
And, she will have to turn the shower off between soaping and rinsing because all that hot water is just going down the drain.
The boiler in our new van has 25 litres of water in it, we can both have a shower, without turning the water off, one after the other and the water is still hot. We could never do this in our old van.
Jan 22, 2013
1,252
59,449
London SE
A class Adria vision I707
since 1971
my shower head has a press button so very easy to stop the flow between soaping down or rinsing off, we don't have a problem but I always let the missus go first so I don't get in the ear in case it does run cold,
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
@Sas r us We have the same boiler as you. We have never run out of hot water in the shower.
We do use it carefully like you but we also have an ecocammel shower head that most certainly helps a lot.
Jun 30, 2010
7,924
27,227
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Get yourselves a Shower head with a Trigger, once you've set the temperature, get wet, soap, rinse, releasing the trigger each time to stop the flow. when you restart the flow again, the water is the same temp.
I've seen trigger/stop/start from a fiver to just over £22. Not quite sure if the fella at Scorrier has them or not
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
My boiler is the 6002 gas only. We both get a shower only 10 minutes apart. Must be on the 60 degrees setting and up to temperature and left ON. Run the shower until the hot water reaches the head and then adjust the temperature by mixing cold.
Get wet & lather head & shoulders then rinse. Lather rest then rinse. We both have a right good wash and with the Ecocamel shower head only use 15 litres between us
sedge
Jul 7, 2009
5,502
13,085
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
We have a gap so it reheats. With long hair, I rarely washed it in the Moho shower.
Oh and none of the little essentials while you're in there! - I'm on about shaving any 'bits' with the shower running, that's all !
Techno
Jul 28, 2010
15,475
20,756
May 2010
Oh & BTW if it starts going cold just reduce the amount of cold water that you're mixing with it!
I usually get showered second as it's a bit too scientific for the ladies :LOL::imoutahere:
Jaws
23,830
72,331
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
We bought one of the Eco Water energy shower heads at a show a couple of years ago.. It was about £15 and I was not really a believer ..
But boy ! It is amazing.. I have NEVER run out of hot water since..
Just found them for sale on Amazon for £12.99
Amazon product ASIN B01DIY1J9A
Oct 12, 2008
6,286
22,393
Balma (next to Toulouse) France
HymerCamp 51Capucine
Since 2011/owner since 6/03/2014
Have a bucket next to the shower, and let her do it her way, but ask her to fill up the bucket while she soaps up. Once shower is over, fill the tank back again with the bucket's water! Easy peasy ! I usually put an empty plastic washing liquid bottle. They have a wide top and it's even better to put the water back in the fresh water tank afterwards!
And yes I too have lots of problems having hot water. Not really a problem in summer, but hell.... in winter I get frozen within 2 seconds!!!
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Do you recommend the Ecocamel shower head Andy ?
Techno
Jul 28, 2010
15,475
20,756
May 2010
There's usually a discount code about that brings it under £25 delivered but I don't have it just now
Techno
Jul 28, 2010
15,475
20,756
May 2010
Discount code is ( Bailey ) which makes it under £24 delivered. They no longer do the Jetstorm E and this model is for all water pressures
Lorryman100
640
1,015
UK/Scotland
Rapido A class
Interesting topic, as we both can shower in our Rapido, one after the other and haven't run out of hot water yet by switching the flow off when lathering. Was interested in the advice about the ecocamel shower head but when looking at a picture of the head fitted in ours it looks very similar to the ecocamel one, anybody know if Rapido fit them as standard?
Just smiffy
May 31, 2015
11,631
44,300
Cornwall
Ducato PVC
Getting Better
Ours does chuck out a fair bit of water so I'll be getting a Eco shower head, in the meantime it's raining outside so I've locked her out and she's getting a good soaking.....:D
CWH
5,137
247,344
UK
WildAx PVC
From November 2013
In a spirit of helpfulness, have you tossed out the shower gel?
Lorryman100
640
1,015
UK/Scotland
Rapido A class
No I don't think so. Ours doesn't have one. I'm about to order one actually as the one in our Rapido isn't that great.
The one fitted in ours is excellent and looks like the ecocamel one? I will leave it as it works for us and save myself the £24.
