shower tap
Discussion in 'Motorhome Chat' started by francour, Sep 15, 2012.
  1. francour
    francour Read Only Funster
    Mar 13, 2012
    94
    13
    Pontefract
    Hi all Boring really but still maybe helpfull collected today from lowdams new hymer shower tap complete with all fittings £103 ordered 8 days ago the old one only needed micro switch but could get inside the b----------- part no 0436026 Thanks Bernie:thumb:
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
  3. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    I recently had to repair one of those shower mixer taps and found it quite simple to get to the "micro switch" if you can really call it that basicly just a spring metal strip that makes contact with another when the tap is turned, cant remember the exact details but from memory there was a cover on the bottom cant remember if it had a couple of screws in it or wether it clipped on but once removed the micro switch just lifted out, all it needed was the contacts cleaning with fine wet & dry and re assembly. however rather than spend twenty odd quid on a seperate pressure switch which can also be a sod to set up I have in the past replaced the original pumps with sureflow pumps (admitidly a little dearer than the switch at around £60) for several customers in the past giving better water pressure and getting rid of the problem of faulty pressure switches in any of the taps.
