Shower smells
Discussion in 'Motorhome Chat' started by combi, Aug 7, 2011.
  1. combi
    combi Read Only Funster
    Aug 23, 2010
    64
    9
    Used the motorhome this weekend and noticed a drains type smell from the shower cubicle and I think it comes from the plughole,
    When we first got the van we flushed the drainage system with Elsan grey water tank fresh and until this weekend there was no problem. On looking underneath I can see that there is no waste trap just a pipe to the waste tank and think that this may be the cause of the problem.
    My question is should I treat the tank more often or is there some way of fitting an anti smell trap.
    Thanks in advance for any help.
    cakeboy
  2. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,662
    14,454
    North Lincolnshire
    I had that.
    Just bunged a bottle of cheap disinfectant down both plug holes and shower.
    Cured it.
  3. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,905
    39,948
    Buy one of them flat`ish rubber/soft plastic sink bungs/plugs and put that on/in when not using the shower.
    Unless the pipe comes out lowish and with a bit of room where it comes through the floor, Doubt you will have the room especially for a free flow. I think you will have a bit of a job on your hands. :Sad:
  4. niggle
    niggle Banned - Rule 1
    Aug 5, 2010
    806
    607
    SOUTH AND FRANCE
    :Rofl1::Rofl1: phor smells in here :Rofl1::Rofl1: no the best is persil soap liqid just pour into all plug holes fill waste tank full let it soak 1/ 2 days it will degrease and clean tank and make it smell better i also use soda crystalls 90 p tesco and it wont harm seals or any thing also same for toilet cheaper the chems in a oaver priced bottle :thumb::thumb:
  5. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi Cakeboy
    The best tip I got re the waste tank, is to put a 2 litre bottle of coke down the plug holes:thumb: add a bit of water then empty after a drive about, all sorts of rubbish comes out:thumb:, then a bottle of smelly to make it smell better:Laughing:, also DONTempty and starchy water down the sink as that will cause smells:Angry:. Pete :thumb::thumb:
  6. lorger
    lorger Funster
    Jul 11, 2008
    6,333
    7,789
    Dumfries
    Hi we where told to put diluting orange juice down the plug holes. we have done this and no smells so far.
  7. champers
    champers Funster Life Member
    Mar 9, 2009
    3,514
    2,118
    Wales
    We had this earlier in the year only from the bathroom sink , I norm leave all the taps open once home but had forgotten on the last one or two occasions when this had occurred
    We couldnt work it out as up to then we were smell free , Phil Taran Las did have some type of smell better /clean it fluid, which helped immediately which i am sure he will be able to tell you when he comes along... loaded it in n went for a drive to swish it about , we remembered then about leaving the taps open when parked up and we have had no prob since although it took us a few weeks to sort out the smell
    Good luck in sorting it... those fragrance lamps are good too if it persists, I believe Andyman's wife sells them...:thumb::thumb::thumb:
  8. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,896
    13,914
    Norfolk
    Make sure nobody uses it before you :Rofl1::Rofl1::Rofl1:
  9. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,999
    395
    Rochester
    Every now and then put biological washing powder/liquid mixed with a drop of water down the plug holes and leave it overnight, works wonders:thumb:
    • Like it Like it x 1
  10. Teasy2007
    Teasy2007 Funster
    Sep 26, 2007
    1,671
    739
    Rotherham South Yorkshire
    Hi we had a similar problem, especially when we were on site for a couple of months. We always leave the plugs in the shower and sink and when we get home we found that using cheap Milton in the fresh water tank, then draining it into the grey water tank and leaving it for a few days with some some disinfectant cleans both tanks and leaves them nice and fresh.
    Ginny
  11. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    most showers are unable to fit a trap just not the drop space available in a van. frequent draining of the grey tank helps along with cleaning. using a biological cold water soap powder will dissolve the crud in the tank and keep it cleaner. We always travel with the plugs in the sinks and shower, that does prevent the stink from a newly drained tank from reaching you. But cleaning it in the first place does help. good luck and as a last resort get nose clips:Rofl1::Rofl1::Rofl1::Rofl1:
  12. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,999
    9,234
    Wrenthorpe, Wakefield.
    We do the same . Empty often waste often and travel with the plugs in.
    Put some washing powder in a bag and keep it in the MH .
    Tip a bit down each plug hole and the shower hole , before setting off and putting the plugs in. Ours never smells doing this.
    In fact it has a nice fresh washing smell if anything. :thumb:
