Shower Room Wall Panels (1 Viewer)
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
We get our new to us 2005 Lunar Roadstar finally next Monday from Marquis @Durham-can't arrive soon enough.
It is generally in excellent condition but the wall panels in the shower room are a bit tatty. My question is then what can be done to refresh these panels?
Is it worthwhile using a waterproof paint type finish or what are your printable recommendations!
Thanks again
Ian
R
Robert Clark
Maybe you could consider sheet laminate as this is available in many finishes and would just need cutting to size
It's only s few mm thick so would not alter the thickness of the cubicle
Broken Link Removed
kelv
672
894
leicester
Carthago 145
Why not recover the walls with some 3mm acrylic panels do Not weigh a lot come in lots of colours adhere to the original walls with a good quality silicon
8,490
11,526
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I used this in our boat --- Broken Link Removed
Comes in board form, about six inch wide and tongue and grooved. Cuts easily and very little waste.
If you want to be very posh they do a chrome divider strip.
3,865
5,246
The City of Henlow
Adria Supreme
Since 1980
I have not attempted this but could you not use plasticised wallpaper attached with spray-on carpet glue? The shower walls in a previous Auto-Sleeper had some form of wallpaper which was partly protected by wrap-around shower curtains.
Alan
musson
487
165
grantham
low profile
since Jan 2014
Hi you can buy shower panels from DIY stores, which you can cut to the size needed,they use them for showers in the house
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
That's the stuff I need thank you..
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
You would too if you had a body like mine!
Broken Link Removed
Maybe a mirror finish, so you can admire from all angles:giggler:
IanF
May 7, 2013
845
1,353
RUK
There might have been an era when that would have boosted my ego but why destroy what's left of it now!
