Shower improvement (1 Viewer)
marksmith
33
19
Hampshire UK
Low profile coachbuilt
Since 2008. Owned since July 2013.
Hi folks,
I was quite pleased with this so I thought I'd share. Might be useful for others.
We use our shower in the van quite a bit, and we tend to wet down, switch off, soap up, rinse off etc. I think I spend more time (and hence water) getting the temperature right than I do actually showering. I bought a shower head from eBay with a trigger, but it was rubbish frankly.
Then I chanced upon this. It's just a ball valve with a male connector one end and female the other. 3/8" BSP, fits right onto the outlet from the mixer. Get the temperature right once, and then just shut it all off with this. Doesn't seem to reduce the flow, and it's easily able to hold back the pressure of the pump. In fact we don't switch the taps off now - just leave them in the right positions for next time.
£2.55 delivered from eBay. Fitted with a bit of PTFE tape to make the thread watertight. Easy.
Broken Link Removed
-Mark
PP Bear
7,805
28,770
Kent, UK
Auto Trail Dakota SE
Seems a great idea and works well for you, but aren't you a little worried that if you leave the taps on and this switch fails, you'll flood or cause yourself problems?
I'm lucky as my shower is fitted with a mixer tap, so don't have that issue. You could always mark the taps in a suitable way and then turn them to the same mark each time to get the same temp :)
Best thing of all, is that it works for you and thanks for sharing :)
M
marksmith
33
19
Hampshire UK
We always switch the pump off when we're not in the van, and when we're in we'd definitely hear it if the valve failed :) No more likely to fail than any of the other parts as far as I can see. All the plumbing is done with push-fit connectors which can come off if disturbed in the right way... so no, not especially concerned :)
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
Techno, the Jetstorm or the Cobra?
Hymie.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Jetstorm for low bar pressure and electric showers. DONT get anything but the low bar or it will be useless.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I just tried code V10 and it took the basket price down to under £20!!!!!!!!!!!!!!!!!!!!!!!!!!
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
£34.90 with postage but comes with a free hose, which I was intending to replace anyway.
Thanks for the heads-up Techno. :notworthy2::notworthy2::notworthy2:
Hymie.
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
Bigger' did I get that wrong or what?
Hymie.
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
I'll have to ring them in the morning.
Thanks again.
Hymie.
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
Thanks Techno, just cancelled and re-ordered, saved a tender thanks to you, owe you a drink if we ever meet.
Hymie.
tedontour
263
125
london
van conversion autocruise
since 1976
me to just ordered 2 £39.94 with v10 code thanks techno (y)
