Should I have a Gaslow system fitted (1 Viewer)
Scuba Steve
41
40
Nottingham
Since 2010
Hello everyone,q I'm looking for some advise on if I should have a GasFlo system fitted?
We do allot of wild camping and whilst I have a solar panel fitted to make sure I have plenty of power, I do find myself using allot of gas and at this time of year I can get through 6kg within 48 hours, I no that's allot but I have a alde wet heating system fitted and although I'm very happy with the heat it gives out it does take a while to heat up and get our motorhome warmed up, I therefore tend to leave the heating on low whilst we are out.
My main problem is the expense of filling up the 6kg each time I go away for a weekend and at somewhere around £22-£25 per cylinder it sometimes defeats the cost saving I'm making by wild camping.
I was therefore thinking of fitting a GasFlow system to reduce my refill costs?
If anyone has any advise I would be very pleased to hear it
Cheers Steve
Nethernut
174
176
NE Scotland
Low profile
since 2010
We have had gas low cylinders in our last 3 motorhomes, great bits of kit, means you can top up anytime. We spend several months a year overseas so can fill up easily at fuel stops selling LPG. And much cheaper, last refill was just under 60p a litre.
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
I've had 2-11kg Gaslow bottles fitted on my last 2 vans, our new van came with under slung tank which releases a gas bottle cupboard for extra storage. The gas low systems I fitted myself quite easily, there is also the Gasit system which is identical to Gaslow but painted red and is cheaper to buy.
John.
irnbru
13,511
31,136
Glasgow
Benimar 264
11 yrs
We will definitely have it fitted in our next MH. It will save you lots of money in the long run. Go for it.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
We have an Alugas bottle ( same thing but alloy bottle) which we have had on our last 3 vans.
Refillables are the way to go.
markh
247
243
C class
Lots
Totally agree, the Gas it system is the same as Gas lo and very easy to fit yourself
D
Deleted member 29692
My main problem is the expense of filling up the 6kg each time I go away for a weekend and at somewhere around £22-£25 per cylinder it sometimes defeats the cost saving I'm making by wild camping. I was therefore thinking of fitting a GasFlow system to reduce my refill costs?
We have Gas low with 2 x 11kg bottles. The last time I filled it was at a petrol station on the A14 so not the cheapest around, 65 or 66p per litre I think. One bottle was empty and one was below 1/4 full according to the gauges. It cost £18.50 to fill them both. You will definitely save on refill costs.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Steve, just ordered a Gasit "dual Gasit Plus bottles" 11kg system, with Euro adapters, 3 meter fill hose for locker fill on the other side of MH. £100 less than Gasflo. Other advantage is Gasit does not have a number 1 and 2 bottle they are both the same. Gasit give 5% to Fun members. Ask for Warren
LOCAL RATE 0845 230 1819 or 01286 832443
No financial connection, just spent a week checking out after Techno's advice!
Brian_K
271
247
Durham
Coach Built
I'm interested in the Gas IT system. Has anyone fitted one of these to an AS Symbol (2004). Wondering what size tank and whether the welded on feet or strap system are best for this vehicle.
Brian
Jan 25, 2013
1,083
22,739
Dorchester, Dorset, UK
Sad former owner
Since 1991
Love the system! No fitting awkward bottles, see autogas and top up rather than wait for a bottle to run out. I reckoned I'd only need to refill 16 times with the associated cheaper gas to recover the cost of fitting the Gasit system. Oh yes, it only took about an hour to fit it - and that's by a DIY numpty like me!
Jan 22, 2013
1,251
59,448
London SE
A class Adria vision I707
since 1971
The only fly in the ointment that I can see is the availabillty of LPG from BP stations, if the rumours are true they are removing LPG from all their stations,
Just means travelling a bit further for a fill up for me, but I wouldn't be without the gas low system after the hassles of lugging colour gas
About on my caravan years ago,
Oct 15, 2012
10,178
57,271
Market Harborough
C Class Laika Ecovip 7R
We had Gas low 2 x 11KG fitted by Dave Newell with the Funster discount and as others have said wouldn't be without it now, cheaper to refill but so easy to fill here and abroad. (y)
Lenny HB
53,304
149,474
On the coast in West Sussex
Hymer B678 DL
With your usage you will recover your cost very quickly but it's more about convenience than cost, as others have said Gas-it is cheaper & just as good (bottles made in the same factory).
Easy to fit for a competent DIY'er.
Lenny HB
53,304
149,474
Hymer B678 DL
I saw that on another forum, a bit of a pain as my nearest LPG station is a BP. A good percentage of lager Shell garages have LPG pumps one of those a couple of miles further not too bad.
Must rember if going to France via Dover to fill up first, as I usually fill up at a BP in Dover as I prefer UK gas, cleaner & 100% propane.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I don't bother where i fill up. Is there any evidence that french gas is different to uk?
Tends to have a higher butane content, particularly in summer (and perhaps when further south). This can make the gas less useful if you have a load left when returning to the UK in winter as butane does not vaporise well at low temperature.
Lenny HB
53,304
149,474
Hymer B678 DL
Met a couple of people on my travels after using French gas have had to clean fridge flue & burner, also My Belgium dealer warned about filling up on French gas. Take a look at this thread a few of the guys in Morocco had problems with fridges not cools all sooted up after filling with Spanish & Moroccan LPG.
Some suppliers put more oil in the gas doesn't matter for auto use with a liquid take off, also doesn't appear to bother heaters (probably due to high throughput), but fridges, jets clog, burners & chimneys soot up.
My last van I service the fridge after 3 years of running on UK Autogas, it didn't need doing everything was clean.
Dometic on the 7000 fridges said not to run on Autogas (every one still did), on the 8000 series they say if running on Autogas should be service every 3 or 6 months.
eddie
8,143
41,176
Taunton Somerset
RV
since 1989
GasIt and Gaslow are both very good systems. However, the systems are not the same!
That is NOT to say that one is better than the other, but for the sake of clarity and members that take everything they read as "read"
As I understand it, Gaslow recommend stainless steel hoses which have a 20 year life span and Gas It use rubber which should be changed every 5 years. Gas It and the old Gaslow bottles were the same but the NewR67 bottles are not the same as either the old Gaslow or GasIt bottles. R67 bottles have internal Excess flow valves which prevents a full flow of gas should a hose rupture.
So both excellent systems, but to say that they are identical is wrong
scotjimland
2,246
9,758
A Woosh bang
I worked in the petrol-chemical refining industry for some years both with Amoco and Shell and didn't know or heard of oil being added to Autogas .. stench yes, but not oil.
happy to be educated.. :)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
When people say that Gaslow & Gasit are identical they refer to the original bottle system and yes one is yellow and one is red but otherwise yes they are and from the same factory. Gaslow do sell a larger product range yes. Choice of hoses is simply a matter of how much money you have but I have had a brand new out of the bag Gaslow stainless hose leak on the weld but they do look pretty
Broken Link Removed
eddie
8,143
41,176
Taunton Somerset
RV
since 1989
The point I was making is that the hose would have to be five times cheaper to be, well cheaper lol
I did stress that I wasn't saying which one was better, but, everytime Gaslow is mentioned, people say that the systems are identical and one is half the price whcih isnt the situation
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes I understand Eddie and often the price difference can be negligible depending on where you buy.
celcat
22
11
Essex
2 years
Techno... probably a dumb question when you tell me.... but why do you need both Gaslo and Calor?
